[petsc-users] error handling
Sam Guo
sam.guo at cd-adapco.com
Mon Jan 20 17:28:35 CST 2020
Does it hurt to call Destroy function without calling CreateFunction? For
example
Mat A, B;
PetscErrorCode <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PetscErrorCode.html#PetscErrorCode>
ierr1, ierr2;
ierr1 = MatCreate
<https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatCreate.html#MatCreate>(PETSC_COMM_WORLD
<https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PETSC_COMM_WORLD.html#PETSC_COMM_WORLD>,&A);
if(ierr1 == 0)
ierr2 = MatCreate
<https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PETSC_COMM_WORLD.html#PETSC_COMM_WORLD>,&B);
if(ierr1 !=0 || ierr2 != 0)
Destroy(&A);
Destroy(&B); // if ierr1 !=0, MatCreat is not called on B. Does it
hurt to call Destroy B here?
On Mon, Jan 20, 2020 at 11:11 AM Dave May <dave.mayhem23 at gmail.com> wrote:
> On Mon 20. Jan 2020 at 19:47, Sam Guo <sam.guo at cd-adapco.com> wrote:
>> Can I assume if there is MatCreat or VecCreate, I should clean up the
>> memory myself?
> Yes. You will need to call the matching Destroy function.
>> On Mon, Jan 20, 2020 at 10:45 AM Sam Guo <sam.guo at cd-adapco.com> wrote:
>>> I only include the first few lines of SLEPc example. What about following
>>> ierr = MatCreate(PETSC_COMM_WORLD,&A);CHKERRQ(ierr);
>>> ierr = MatSetSizes(A,PETSC_DECIDE,PETSC_DECIDE,n,n);CHKERRQ(ierr);
>>> Is there any memory lost?
>>> On Mon, Jan 20, 2020 at 10:41 AM Dave May <dave.mayhem23 at gmail.com>
>>> wrote:
>>>> On Mon 20. Jan 2020 at 19:39, Sam Guo <sam.guo at cd-adapco.com> wrote:
>>>>> I don't have a specific case yet. Currently every call of PETSc is
>>>>> checked. If ierr is not zero, print the error and return. For example,
>>>>> Mat A; /* problem matrix */
>>>>> EPS eps; /* eigenproblem solver context */
>>>>> EPSType type;
>>>>> PetscReal error,tol,re,im;
>>>>> PetscScalar kr,ki; Vec xr,xi; 25
>>>>> PetscInt n=30,i,Istart,Iend,nev,maxit,its,nconv;
>>>>> PetscErrorCode ierr;
>>>>> ierr = SlepcInitialize(&argc,&argv,(char*)0,help);CHKERRQ(ierr);
>>>>> ierr = PetscOptionsGetInt(NULL,NULL,"-n",&n,NULL);CHKERRQ(ierr);
>>>>> ierr = PetscPrintf(PETSC_COMM_WORLD,"\n1-D Laplacian Eigenproblem,
>>>>> n=%D\n\n",n);CHKERRQ(ierr);
>>>>> I am wondering if the memory is lost by calling CHKERRQ.
>>>> No.
>>>>> On Mon, Jan 20, 2020 at 10:14 AM Dave May <dave.mayhem23 at gmail.com>
>>>>> wrote:
>>>>>> On Mon 20. Jan 2020 at 19:11, Sam Guo <sam.guo at cd-adapco.com> wrote:
>>>>>>> Dear PETSc dev team,
>>>>>>> If PETSc function returns an error, what's the correct way to
>>>>>>> clean PETSc?
>>>>>> The answer depends on the error message reported. Send the complete
>>>>>> error message and a better answer can be provided.
>>>>>> Particularly how to clean up the memory?
>>>>>> Totally depends on the objects which aren’t being freed. You need to
>>>>>> provide more information
>>>>>> Thanks
>>>>>> Dave
>>>>>>> Thanks,
>>>>>>> Sam
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200120/83919c15/attachment.html>
