[petsc-users] error handling
Sam Guo
sam.guo at cd-adapco.com
Mon Jan 20 17:30:24 CST 2020
I mean MatDestroy.
On Mon, Jan 20, 2020 at 3:28 PM Sam Guo <sam.guo at cd-adapco.com> wrote:
> Does it hurt to call Destroy function without calling CreateFunction? For
> example
> Mat A, B;
> PetscErrorCode <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PetscErrorCode.html#PetscErrorCode> ierr1, ierr2;
> ierr1 = MatCreate <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatCreate.html#MatCreate>(PETSC_COMM_WORLD <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PETSC_COMM_WORLD.html#PETSC_COMM_WORLD>,&A);
> if(ierr1 == 0)
> ierr2 = MatCreate <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatCreate.html#MatCreate>(PETSC_COMM_WORLD <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PETSC_COMM_WORLD.html#PETSC_COMM_WORLD>,&B);
> if(ierr1 !=0 || ierr2 != 0)
> Destroy(&A);
> Destroy(&B); // if ierr1 !=0, MatCreat is not called on B. Does it hurt to call Destroy B here?
> On Mon, Jan 20, 2020 at 11:11 AM Dave May <dave.mayhem23 at gmail.com> wrote:
>> On Mon 20. Jan 2020 at 19:47, Sam Guo <sam.guo at cd-adapco.com> wrote:
>>> Can I assume if there is MatCreat or VecCreate, I should clean up the
>>> memory myself?
>> Yes. You will need to call the matching Destroy function.
>>> On Mon, Jan 20, 2020 at 10:45 AM Sam Guo <sam.guo at cd-adapco.com> wrote:
>>>> I only include the first few lines of SLEPc example. What about
>>>> following
>>>> ierr = MatCreate(PETSC_COMM_WORLD,&A);CHKERRQ(ierr);
>>>> ierr = MatSetSizes(A,PETSC_DECIDE,PETSC_DECIDE,n,n);CHKERRQ(ierr);
>>>> Is there any memory lost?
>>>> On Mon, Jan 20, 2020 at 10:41 AM Dave May <dave.mayhem23 at gmail.com>
>>>> wrote:
>>>>> On Mon 20. Jan 2020 at 19:39, Sam Guo <sam.guo at cd-adapco.com> wrote:
>>>>>> I don't have a specific case yet. Currently every call of PETSc is
>>>>>> checked. If ierr is not zero, print the error and return. For example,
>>>>>> Mat A; /* problem matrix */
>>>>>> EPS eps; /* eigenproblem solver context */
>>>>>> EPSType type;
>>>>>> PetscReal error,tol,re,im;
>>>>>> PetscScalar kr,ki; Vec xr,xi; 25
>>>>>> PetscInt n=30,i,Istart,Iend,nev,maxit,its,nconv;
>>>>>> PetscErrorCode ierr;
>>>>>> ierr = SlepcInitialize(&argc,&argv,(char*)0,help);CHKERRQ(ierr);
>>>>>> ierr = PetscOptionsGetInt(NULL,NULL,"-n",&n,NULL);CHKERRQ(ierr);
>>>>>> ierr = PetscPrintf(PETSC_COMM_WORLD,"\n1-D Laplacian Eigenproblem,
>>>>>> n=%D\n\n",n);CHKERRQ(ierr);
>>>>>> I am wondering if the memory is lost by calling CHKERRQ.
>>>>> No.
>>>>>> On Mon, Jan 20, 2020 at 10:14 AM Dave May <dave.mayhem23 at gmail.com>
>>>>>> wrote:
>>>>>>> On Mon 20. Jan 2020 at 19:11, Sam Guo <sam.guo at cd-adapco.com> wrote:
>>>>>>>> Dear PETSc dev team,
>>>>>>>> If PETSc function returns an error, what's the correct way to
>>>>>>>> clean PETSc?
>>>>>>> The answer depends on the error message reported. Send the complete
>>>>>>> error message and a better answer can be provided.
>>>>>>> Particularly how to clean up the memory?
>>>>>>> Totally depends on the objects which aren’t being freed. You need to
>>>>>>> provide more information
>>>>>>> Thanks
>>>>>>> Dave
>>>>>>>> Thanks,
>>>>>>>> Sam
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200120/55cf4187/attachment.html>
