[petsc-users] chowiluviennacl
Xiangdong epscodes at gmail.com
Wed Jan 15 08:35:47 CST 2020
Can chowiluviennacl do ilu0?
I need to solve a tri-diagonal system directly. If I apply the PCILU, I
will obtain the exact solution with preonly + pcilu. However, the preonly +
chowiluviennacl will not provide the exact solution. Any option keys to set
the CHOWILUVIENNACL filling level or dropping off tolerance like the
standard ilu?
Thank you.
Best,
Xiangdong
On Tue, Jan 14, 2020 at 10:05 PM Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, Jan 14, 2020 at 9:56 PM Xiangdong <epscodes at gmail.com> wrote:
>> Dear Developers,
>> I have a quick question about the chowiluviennacl. When I tried to use
>> it, I found that it only works for np=1, not np>1. However, in the
>> description of chowiluviennacl.cxx, it says "the ViennaCL Chow-Patel
>> parallel ILU preconditioner".
> By parallel, this means shared memory parallelism on the GPU.
>> I am wondering whether I am using it correctly. Does chowiluviennacl work
>> for np>1?
> I do not believe so. I do not see why it could not be extended, but that
> would mean writing some more code.
>   Thanks,
>     Matt
>> In addition, are there option keys for the chowiluviennacl one can try?
>> Thank you.
>> Best,
>> Xiangdong
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200115/36a1623d/attachment.html>
