[petsc-users] chowiluviennacl
Tue Jan 14 21:04:51 CST 2020
On Tue, Jan 14, 2020 at 9:56 PM Xiangdong <epscodes at gmail.com> wrote:
> Dear Developers,
> I have a quick question about the chowiluviennacl. When I tried to use it,
> I found that it only works for np=1, not np>1. However, in the description
> of chowiluviennacl.cxx, it says "the ViennaCL Chow-Patel parallel ILU
> preconditioner".
By parallel, this means shared memory parallelism on the GPU.
> I am wondering whether I am using it correctly. Does chowiluviennacl work
> for np>1?
I do not believe so. I do not see why it could not be extended, but that
would mean writing some more code.
    Matt
> In addition, are there option keys for the chowiluviennacl one can try?
> Thank you.
> Best,
> Xiangdong
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200114/348142b2/attachment.html>
