[petsc-users] chowiluviennacl
Matthew Knepley
knepley at gmail.com
Wed Jan 15 08:40:56 CST 2020
On Wed, Jan 15, 2020 at 9:36 AM Xiangdong <epscodes at gmail.com> wrote:
> Can chowiluviennacl do ilu0?
> I need to solve a tri-diagonal system directly. If I apply the PCILU, I
> will obtain the exact solution with preonly + pcilu. However, the preonly +
> chowiluviennacl will not provide the exact solution. Any option keys to set
> the CHOWILUVIENNACL filling level or dropping off tolerance like the
> standard ilu?
No. However, such a scheme makes less sense here. This algorithm spawns a
individual threads for individual elements. Drop tolerance
is not less work, it is sparser, but that should not matter for a
tridiagonal system. Levels also is not applicable since you have only 1
level.
Matt
> Thank you.
> Best,
> Xiangdong
> On Tue, Jan 14, 2020 at 10:05 PM Matthew Knepley <knepley at gmail.com>
> wrote:
>> On Tue, Jan 14, 2020 at 9:56 PM Xiangdong <epscodes at gmail.com> wrote:
>>> Dear Developers,
>>> I have a quick question about the chowiluviennacl. When I tried to use
>>> it, I found that it only works for np=1, not np>1. However, in the
>>> description of chowiluviennacl.cxx, it says "the ViennaCL Chow-Patel
>>> parallel ILU preconditioner".
>> By parallel, this means shared memory parallelism on the GPU.
>>> I am wondering whether I am using it correctly. Does chowiluviennacl
>>> work for np>1?
>> I do not believe so. I do not see why it could not be extended, but that
>> would mean writing some more code.
>> Thanks,
>> Matt
>>> In addition, are there option keys for the chowiluviennacl one can try?
>>> Thank you.
>>> Best,
>>> Xiangdong
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200115/0078e75e/attachment.html>
