[petsc-users] DMUMPS_LOAD_RECV_MSGS
Matthew Knepley
knepley at gmail.com
Thu Feb 13 08:31:43 CST 2020
On Thu, Feb 13, 2020 at 5:53 AM Perceval Desforges <
perceval.desforges at polytechnique.edu> wrote:
> Hello all,
> I have been running in a strange issue with petsc, and more specifically I
> believe Mumps is the problem.
> In my program, I run a loop where at the beginning of the loop I create an
> eps object, calculate the eigenvalues in a certain interval using the
> spectrum slicing method, store them, and then destroy the eps object. For
> some reason, whatever the problem size, if my loop has too many iterations
> (over 2040 I believe), the program will crash giving me this error :
> Internal error 1 in DMUMPS_LOAD_RECV_MSGS 0
> application called MPI_Abort(MPI_COMM_WORLD, -99) - process 0
> I am running the program in MPI over 20 processes.
> I don't really understand what this message means, does anybody know?
An easy test would be to replace MUMPS with SuperLU and see if the error
persists.
Matt
> Best regards,
> Perceval
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200213/857f8458/attachment.html>
