[petsc-users] Support for full jacobianP in TSSetIJacobianP
    Zhang, Hong
    hongzhang at anl.gov
    Fri Dec 18 17:11:50 CST 2020
The current interface is general and should be applicable to this case as soon as users can provide IJacobianP, which is dF(Udot,U,P,t)/dP. Were you able to generate it in firedrake? If so, could you provide an example that I can test?
Hong
On Dec 18, 2020, at 10:58 AM, Salazar De Troya, Miguel <salazardetro1 at llnl.gov<mailto:salazardetro1 at llnl.gov>> wrote:
Yes, that is the case I am considering. The special case I am concerned about is as following: the heat equation in variational form and in firedrake/UFL notation is as follows: p*u_t*v*dx + inner(grad(u), grad(v))*dx = 0, where u is the temperature, u_t is its time derivative, v is just the test function, dx is the integration domain and p is the design parameter. If “p” were discontinuous, one can’t just factor “p” into the second term due to the divergence theorem. Meaning that p*u_t*v*dx + inner(grad(u), grad(v))*dx = 0 is different than u_t*v*dx + inner(1.0 / p * grad(u), grad(v))*dx = 0, which is what ideally one would obtain in order to adapt to the current interface in TSAdjoint.
Thanks
Miguel
From: "Zhang, Hong" <hongzhang at anl.gov<mailto:hongzhang at anl.gov>>
Date: Thursday, December 17, 2020 at 7:25 PM
To: "Salazar De Troya, Miguel" <salazardetro1 at llnl.gov<mailto:salazardetro1 at llnl.gov>>
Cc: Satish Balay via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>>
Subject: Re: [petsc-users] Support for full jacobianP in TSSetIJacobianP
Hi Miguel,
Thank you for the nice work. I do not understand what you propose to do here. What is the obstacle to using current TSSetIJacobianP() for the corner case you mentioned? Are you considering a case in which the mass matrix is parameterized, e.g. M(p) udot - f(t,u) = g(t,u) ?
Hong
On Dec 17, 2020, at 3:38 PM, Salazar De Troya, Miguel via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
Hello,
I am working on hooking up TSAdjoint with pyadjoint through the firedrake-ts interface (https://github.com/IvanYashchuk/firedrake-ts). I have done most of the implementation and now I am just testing for corner cases. One of them is when the design variable is multiplying the first derivative term. It would be the case ofF(Udot,U,P,t) = G(U,P,t) in https://www.mcs.anl.gov/petsc/petsc-master/docs/manualpages/Sensitivity/TSSetIJacobianP.html . I imagine that one could think of refactoring the “P” in the left hand side to the right hand side, but this is not trivial when “P” is a discontinuous field over the domain. I think it would be better to include the case of F(Udot,U,P,t) = G(U,P,t) in TSSetIJacobianP and I am volunteering to do it. Given the current implementation of TSAdjoint, is this something feasible?
Thanks
Miguel
Miguel A. Salazar de Troya
Postdoctoral Researcher, Lawrence Livermore National Laboratory
B141
Rm: 1085-5
Ph: 1(925) 422-6411
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20201218/e890e20a/attachment.html>
