[petsc-users] Support for full jacobianP in TSSetIJacobianP
Salazar De Troya, Miguel salazardetro1 at llnl.gov
Fri Dec 18 18:35:41 CST 2020
Ok, I was not able to get such case to work in my firedrake-ts implementation. Maybe I am missing something in my code. I looked at the TSAdjoint paper https://arxiv.org/pdf/1912.07696.pdf Equation 2.1 and at the adjoint method for the theta method (Equation 2.15) where the mass matrix is not differentiated w.r.t. the design parameter “p” and decided to ask the question. Is the actual implementation different from what is in the paper?
Thanks
Miguel
Date: Friday, December 18, 2020 at 3:11 PM
To: "Salazar De Troya, Miguel" <salazardetro1 at llnl.gov>
Cc: Satish Balay via petsc-users <petsc-users at mcs.anl.gov>
Subject: Re: [petsc-users] Support for full jacobianP in TSSetIJacobianP
The current interface is general and should be applicable to this case as soon as users can provide IJacobianP, which is dF(Udot,U,P,t)/dP. Were you able to generate it in firedrake? If so, could you provide an example that I can test?
Hong
On Dec 18, 2020, at 10:58 AM, Salazar De Troya, Miguel <salazardetro1 at llnl.gov<mailto:salazardetro1 at llnl.gov>> wrote:
Yes, that is the case I am considering. The special case I am concerned about is as following: the heat equation in variational form and in firedrake/UFL notation is as follows: p*u_t*v*dx + inner(grad(u), grad(v))*dx = 0, where u is the temperature, u_t is its time derivative, v is just the test function, dx is the integration domain and p is the design parameter. If “p” were discontinuous, one can’t just factor “p” into the second term due to the divergence theorem. Meaning that p*u_t*v*dx + inner(grad(u), grad(v))*dx = 0 is different than u_t*v*dx + inner(1.0 / p * grad(u), grad(v))*dx = 0, which is what ideally one would obtain in order to adapt to the current interface in TSAdjoint.
Thanks
Miguel
From: "Zhang, Hong" <hongzhang at anl.gov<mailto:hongzhang at anl.gov>>
Date: Thursday, December 17, 2020 at 7:25 PM
To: "Salazar De Troya, Miguel" <salazardetro1 at llnl.gov<mailto:salazardetro1 at llnl.gov>>
Cc: Satish Balay via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>>
Hi Miguel,
Thank you for the nice work. I do not understand what you propose to do here. What is the obstacle to using current TSSetIJacobianP() for the corner case you mentioned? Are you considering a case in which the mass matrix is parameterized, e.g. M(p) udot - f(t,u) = g(t,u) ?
Hong
On Dec 17, 2020, at 3:38 PM, Salazar De Troya, Miguel via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
Hello,
I am working on hooking up TSAdjoint with pyadjoint through the firedrake-ts interface (https://github.com/IvanYashchuk/firedrake-ts). I have done most of the implementation and now I am just testing for corner cases. One of them is when the design variable is multiplying the first derivative term. It would be the case ofF(Udot,U,P,t) = G(U,P,t) in https://www.mcs.anl.gov/petsc/petsc-master/docs/manualpages/Sensitivity/TSSetIJacobianP.html . I imagine that one could think of refactoring the “P” in the left hand side to the right hand side, but this is not trivial when “P” is a discontinuous field over the domain. I think it would be better to include the case of F(Udot,U,P,t) = G(U,P,t) in TSSetIJacobianP and I am volunteering to do it. Given the current implementation of TSAdjoint, is this something feasible?
Thanks
Miguel
Miguel A. Salazar de Troya
Postdoctoral Researcher, Lawrence Livermore National Laboratory
B141
Rm: 1085-5
Ph: 1(925) 422-6411
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20201219/adc3076b/attachment-0001.html>
