[petsc-users] TS tutorial ex11 in Fortran
Thibault Bridel-Bertomeu
thibault.bridelbertomeu at gmail.com
Wed Dec 16 00:35:53 CST 2020
Hello everyone,
Thank you Barry for the feedback.
OK, yes I'll work up an MR as soon as I have got something working. By the
way, does the fortran-version of the example have to be a single file ? If
my push contains a directory with several files (different modules and the
main), and the Makefile that goes with it, is that ok ?
Le mer. 16 déc. 2020 à 04:46, Barry Smith <bsmith at petsc.dev> a écrit :
> This is great. If you make a branch off of the PETSc git repository
> with these additions and work on ex11 you can make a merge request and we
> can run the code easily on all our test systems (for security reasons one
> of use needs to launch the tests from your MR).
> https://docs.petsc.org/en/latest/developers/integration/
> Barry
> On Dec 15, 2020, at 5:35 AM, Thibault Bridel-Bertomeu <
> thibault.bridelbertomeu at gmail.com> wrote:
> Hello everyone,
> So far, I have the wrappers in the files attached to this e-mail. I still
> do not know if they work properly - at least the code compiles and the
> calls to the wrapped-subroutine do not fail - but I wanted to put this here
> in case someone sees something really wrong with it already.
> Thank you again for your help, I'll try to post updates of the F90 version
> of ex11 regularly in this thread.
> Stay safe,
> Le dim. 13 déc. 2020 à 16:39, Jed Brown <jed at jedbrown.org> a écrit :
>> Thibault Bridel-Bertomeu <thibault.bridelbertomeu at gmail.com> writes:
>> > Thank you Mark for your answer.
>> > I am not sure what you think could be in the setBC1 routine ? How to
>> make
>> > the connection with the PetscDS ?
>> > On the other hand, I actually found after a while TSMonitorSet has a
>> > fortran wrapper, and it does take as arguments two function pointers,
>> so I
>> > guess it is possible ? Although I am not sure exactly how to play with
>> the
>> > PetscObjectSetFortranCallback & PetscObjectUseFortranCallback macros -
>> > could anybody advise please ?
>> tsmonitorset_ is a good example to follow. In your file, create one of
>> these static structs with a member for each callback. These are IDs that
>> will be used as keys for Fortran callbacks and their contexts. The salient
>> parts of the file are below.
>> static struct {
>> PetscFortranCallbackId prestep;
>> PetscFortranCallbackId poststep;
>> PetscFortranCallbackId rhsfunction;
>> PetscFortranCallbackId rhsjacobian;
>> PetscFortranCallbackId ifunction;
>> PetscFortranCallbackId ijacobian;
>> PetscFortranCallbackId monitor;
>> PetscFortranCallbackId mondestroy;
>> PetscFortranCallbackId transform;
>> #if defined(PETSC_HAVE_F90_2PTR_ARG)
>> PetscFortranCallbackId function_pgiptr;
>> #endif
>> } _cb;
>> Note ctx is the same as ts so we need to get the Fortran context out
>> of the TS; this gets put in _ctx using the callback ID
>> static PetscErrorCode ourmonitor(TS ts,PetscInt i,PetscReal d,Vec v,void
>> *ctx)
>> PetscObjectUseFortranCallback(ts,_cb.monitor,(TS*,PetscInt*,PetscReal*,Vec
>> *,void*,PetscErrorCode*),(&ts,&i,&d,&v,_ctx,&ierr));
>> Then follow as in tsmonitorset_, which sets two callbacks.
>> PETSC_EXTERN void tsmonitorset_(TS *ts,void
>> (*func)(TS*,PetscInt*,PetscReal*,Vec*,void*,PetscErrorCode*),void
>> *mctx,void (*d)(void*,PetscErrorCode*),PetscErrorCode *ierr)
>> CHKFORTRANNULLFUNCTION(d);
>> if ((PetscVoidFunction)func == (PetscVoidFunction) tsmonitordefault_) {
>> *ierr = TSMonitorSet(*ts,(PetscErrorCode
>> (*)(TS,PetscInt,PetscReal,Vec,void*))TSMonitorDefault,*(PetscViewerAndFormat**)mctx,(PetscErrorCode
>> (*)(void **))PetscViewerAndFormatDestroy);
>> } else {
>> *ierr =
>> PetscObjectSetFortranCallback((PetscObject)*ts,PETSC_FORTRAN_CALLBACK_CLASS,&_cb.monitor,(PetscVoidFunction)func,mctx);
>> *ierr =
>> PetscObjectSetFortranCallback((PetscObject)*ts,PETSC_FORTRAN_CALLBACK_CLASS,&_cb.mondestroy,(PetscVoidFunction)d,mctx);
>> *ierr = TSMonitorSet(*ts,ourmonitor,*ts,ourmonitordestroy);
> <wrapper_petsc.h90><wrapper_petsc.c>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20201216/dc352c85/attachment-0001.html>
