[petsc-users] TS tutorial ex11 in Fortran
Barry Smith
bsmith at petsc.dev
Tue Dec 15 21:46:00 CST 2020
This is great. If you make a branch off of the PETSc git repository with these additions and work on ex11 you can make a merge request and we can run the code easily on all our test systems (for security reasons one of use needs to launch the tests from your MR). https://docs.petsc.org/en/latest/developers/integration/
Barry
> On Dec 15, 2020, at 5:35 AM, Thibault Bridel-Bertomeu <thibault.bridelbertomeu at gmail.com> wrote:
> Hello everyone,
> So far, I have the wrappers in the files attached to this e-mail. I still do not know if they work properly - at least the code compiles and the calls to the wrapped-subroutine do not fail - but I wanted to put this here in case someone sees something really wrong with it already.
> Thank you again for your help, I'll try to post updates of the F90 version of ex11 regularly in this thread.
> Stay safe,
> Le dim. 13 déc. 2020 à 16:39, Jed Brown <jed at jedbrown.org <mailto:jed at jedbrown.org>> a écrit :
> Thibault Bridel-Bertomeu <thibault.bridelbertomeu at gmail.com <mailto:thibault.bridelbertomeu at gmail.com>> writes:
> > Thank you Mark for your answer.
> > I am not sure what you think could be in the setBC1 routine ? How to make
> > the connection with the PetscDS ?
> > On the other hand, I actually found after a while TSMonitorSet has a
> > fortran wrapper, and it does take as arguments two function pointers, so I
> > guess it is possible ? Although I am not sure exactly how to play with the
> > PetscObjectSetFortranCallback & PetscObjectUseFortranCallback macros -
> > could anybody advise please ?
> tsmonitorset_ is a good example to follow. In your file, create one of these static structs with a member for each callback. These are IDs that will be used as keys for Fortran callbacks and their contexts. The salient parts of the file are below.
> static struct {
> PetscFortranCallbackId prestep;
> PetscFortranCallbackId poststep;
> PetscFortranCallbackId rhsfunction;
> PetscFortranCallbackId rhsjacobian;
> PetscFortranCallbackId ifunction;
> PetscFortranCallbackId ijacobian;
> PetscFortranCallbackId monitor;
> PetscFortranCallbackId mondestroy;
> PetscFortranCallbackId transform;
> #if defined(PETSC_HAVE_F90_2PTR_ARG)
> PetscFortranCallbackId function_pgiptr;
> #endif
> } _cb;
> Note ctx is the same as ts so we need to get the Fortran context out of the TS; this gets put in _ctx using the callback ID
> static PetscErrorCode ourmonitor(TS ts,PetscInt i,PetscReal d,Vec v,void *ctx)
> PetscObjectUseFortranCallback(ts,_cb.monitor,(TS*,PetscInt*,PetscReal*,Vec *,void*,PetscErrorCode*),(&ts,&i,&d,&v,_ctx,&ierr));
> Then follow as in tsmonitorset_, which sets two callbacks.
> PETSC_EXTERN void tsmonitorset_(TS *ts,void (*func)(TS*,PetscInt*,PetscReal*,Vec*,void*,PetscErrorCode*),void *mctx,void (*d)(void*,PetscErrorCode*),PetscErrorCode *ierr)
> CHKFORTRANNULLFUNCTION(d);
> if ((PetscVoidFunction)func == (PetscVoidFunction) tsmonitordefault_) {
> *ierr = TSMonitorSet(*ts,(PetscErrorCode (*)(TS,PetscInt,PetscReal,Vec,void*))TSMonitorDefault,*(PetscViewerAndFormat**)mctx,(PetscErrorCode (*)(void **))PetscViewerAndFormatDestroy);
> } else {
> *ierr = PetscObjectSetFortranCallback((PetscObject)*ts,PETSC_FORTRAN_CALLBACK_CLASS,&_cb.monitor,(PetscVoidFunction)func,mctx);
> *ierr = PetscObjectSetFortranCallback((PetscObject)*ts,PETSC_FORTRAN_CALLBACK_CLASS,&_cb.mondestroy,(PetscVoidFunction)d,mctx);
> *ierr = TSMonitorSet(*ts,ourmonitor,*ts,ourmonitordestroy);
> <wrapper_petsc.h90><wrapper_petsc.c>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20201215/d5647770/attachment.html>
