[petsc-users] TS tutorial ex11 in Fortran
    Barry Smith
    bsmith at petsc.dev
    Wed Dec 16 00:47:46 CST 2020
  Thibault,
  A subdirectory for the example is fine; we have other examples that use subdirectories and multiple files.
  Note: even if you don't have something completely working you can still make MR and list it as DRAFT request for comments, some other PETSc members who understand the packages you are using and Fortran better than I may be able to help as you develop the code.
  Barry
> On Dec 16, 2020, at 12:35 AM, Thibault Bridel-Bertomeu <thibault.bridelbertomeu at gmail.com> wrote:
> Hello everyone,
> Thank you Barry for the feedback.
> OK, yes I'll work up an MR as soon as I have got something working. By the way, does the fortran-version of the example have to be a single file ? If my push contains a directory with several files (different modules and the main), and the Makefile that goes with it, is that ok ?
> Le mer. 16 déc. 2020 à 04:46, Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev>> a écrit :
>   This is great. If you make a branch off of the PETSc  git repository with these additions and work on ex11 you can make a merge request and we can run the code easily on all our test systems (for security reasons one of use needs to launch the tests from your MR).  https://docs.petsc.org/en/latest/developers/integration/ <https://docs.petsc.org/en/latest/developers/integration/>
>    Barry
>> On Dec 15, 2020, at 5:35 AM, Thibault Bridel-Bertomeu <thibault.bridelbertomeu at gmail.com <mailto:thibault.bridelbertomeu at gmail.com>> wrote:
>> Hello everyone,
>> So far, I have the wrappers in the files attached to this e-mail. I still do not know if they work properly - at least the code compiles and the calls to the wrapped-subroutine do not fail - but I wanted to put this here in case someone sees something really wrong with it already.
>> Thank you again for your help, I'll try to post updates of the F90 version of ex11 regularly in this thread.
>> Stay safe,
>> Le dim. 13 déc. 2020 à 16:39, Jed Brown <jed at jedbrown.org <mailto:jed at jedbrown.org>> a écrit :
>> Thibault Bridel-Bertomeu <thibault.bridelbertomeu at gmail.com <mailto:thibault.bridelbertomeu at gmail.com>> writes:
>> > Thank you Mark for your answer.
>> > I am not sure what you think could be in the setBC1 routine ? How to make
>> > the connection with the PetscDS ?
>> > On the other hand, I actually found after a while TSMonitorSet has a
>> > fortran wrapper, and it does take as arguments two function pointers, so I
>> > guess it is possible ? Although I am not sure exactly how to play with the
>> > PetscObjectSetFortranCallback & PetscObjectUseFortranCallback macros -
>> > could anybody advise please ?
>> tsmonitorset_ is a good example to follow. In your file, create one of these static structs with a member for each callback. These are IDs that will be used as keys for Fortran callbacks and their contexts. The salient parts of the file are below.
>> static struct {
>>   PetscFortranCallbackId prestep;
>>   PetscFortranCallbackId poststep;
>>   PetscFortranCallbackId rhsfunction;
>>   PetscFortranCallbackId rhsjacobian;
>>   PetscFortranCallbackId ifunction;
>>   PetscFortranCallbackId ijacobian;
>>   PetscFortranCallbackId monitor;
>>   PetscFortranCallbackId mondestroy;
>>   PetscFortranCallbackId transform;
>> #if defined(PETSC_HAVE_F90_2PTR_ARG)
>>   PetscFortranCallbackId function_pgiptr;
>> #endif
>> } _cb;
>>    Note ctx is the same as ts so we need to get the Fortran context out of the TS; this gets put in _ctx using the callback ID
>> static PetscErrorCode ourmonitor(TS ts,PetscInt i,PetscReal d,Vec v,void *ctx)
>>   PetscObjectUseFortranCallback(ts,_cb.monitor,(TS*,PetscInt*,PetscReal*,Vec *,void*,PetscErrorCode*),(&ts,&i,&d,&v,_ctx,&ierr));
>> Then follow as in tsmonitorset_, which sets two callbacks.
>> PETSC_EXTERN void tsmonitorset_(TS *ts,void (*func)(TS*,PetscInt*,PetscReal*,Vec*,void*,PetscErrorCode*),void *mctx,void (*d)(void*,PetscErrorCode*),PetscErrorCode *ierr)
>>   CHKFORTRANNULLFUNCTION(d);
>>   if ((PetscVoidFunction)func == (PetscVoidFunction) tsmonitordefault_) {
>>     *ierr = TSMonitorSet(*ts,(PetscErrorCode (*)(TS,PetscInt,PetscReal,Vec,void*))TSMonitorDefault,*(PetscViewerAndFormat**)mctx,(PetscErrorCode (*)(void **))PetscViewerAndFormatDestroy);
>>   } else {
>>     *ierr = PetscObjectSetFortranCallback((PetscObject)*ts,PETSC_FORTRAN_CALLBACK_CLASS,&_cb.monitor,(PetscVoidFunction)func,mctx);
>>     *ierr = PetscObjectSetFortranCallback((PetscObject)*ts,PETSC_FORTRAN_CALLBACK_CLASS,&_cb.mondestroy,(PetscVoidFunction)d,mctx);
>>     *ierr = TSMonitorSet(*ts,ourmonitor,*ts,ourmonitordestroy);
>> <wrapper_petsc.h90><wrapper_petsc.c>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20201216/d0f53283/attachment.html>
