[petsc-users] Unexplained memory leaks
Matthew Knepley
knepley at gmail.com
Fri Aug 28 12:36:47 CDT 2020
On Fri, Aug 28, 2020 at 1:32 PM baikadi pranay <pranayreddy865 at gmail.com>
wrote:
> Thank you Mark and Matthew. I will try to use the suppression file to hide
> the leaks.
> On a different note, I see a similar error related to MPI when I couple my
> poisson solver with the schrodinger solver (written with SLEPc). I am
> attaching a screenshot of the error. I was wondering if you could comment
> on this issue as well.
> Please let me know if you need any further information from me.
It looks like you called an MPI function after you called PetscFinalize().
In order to do this, you have to call MPI_Init() before you call
PetscInitialize().
Matt
> Thank you.
> Best Regards,
> Pranay.
> ᐧ
> On Fri, Aug 28, 2020 at 5:48 AM Mark Lohry <mlohry at gmail.com> wrote:
>> Looking through my own valgrind I saw OpenMPI mentions on their faq they
>> provide a suppression file to hide their known leaks:
>> https://www.open-mpi.org/faq/?category=debugging#valgrind_clean
>> mpirun -np 2 valgrind --suppressions=$PREFIX/share/openmpi/openmpi-valgrind.supp
>> On Fri, Aug 28, 2020 at 7:41 AM Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> OpenMPI leaks memory at the end. As you can see it is small, so they are
>>> unmotivated to fix that.
>>> Thanks,
>>> Matt
>>> On Fri, Aug 28, 2020 at 4:31 AM baikadi pranay <pranayreddy865 at gmail.com>
>>> wrote:
>>>> Hi,
>>>> I am building a 2D solver for the semiconductor Poisson-Boltzmann
>>>> equation. I detected a memory leak when running the program using valgrind
>>>> but I am unable to solve this issue as there are no signs in the valgrind
>>>> output indicating that the source of the error is in the modules I have
>>>> written. I am attaching you a text file containing the valgrind output.
>>>> I have seen that a similar question was asked earlier (found here
>>>> <https://lists.mcs.anl.gov/pipermail/petsc-users/2010-October/007132.html>)
>>>> but I could not find a final solution to that problem. Could you let me
>>>> know the source of the problem?
>>>> Please let me know if you need any further information.
>>>> Thank you,
>>>> Pranay.
>>>> ᐧ
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/
>>> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200828/41366502/attachment.html>
