[petsc-users] PetscFV and TS implicit
Barry Smith bsmith at petsc.dev
Fri Aug 21 10:22:19 CDT 2020
> On Aug 21, 2020, at 8:35 AM, Thibault Bridel-Bertomeu <thibault.bridelbertomeu at gmail.com> wrote:
> Le ven. 21 août 2020 à 15:23, Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com>> a écrit :
> On Fri, Aug 21, 2020 at 9:10 AM Thibault Bridel-Bertomeu <thibault.bridelbertomeu at gmail.com <mailto:thibault.bridelbertomeu at gmail.com>> wrote:
> Sorry, I sent too soon, I hit the wrong key.
> I wanted to say that context.npoints is the local number of cells.
> PetscRHSFunctionImpl allows to generate the hyperbolic part of the right hand side.
> Then we have :
> PetscErrorCode PetscIJacobian(
>                                TS ts,        /*!< Time stepping object (see PETSc TS)*/
>                                PetscReal t,  /*!< Current time */
>                                Vec Y,        /*!< Solution vector */
>                                Vec Ydot,     /*!< Time-derivative of solution vector */
>                                PetscReal a,  /*!< Shift */
>                                Mat A,        /*!< Jacobian matrix */
>                                Mat B,        /*!< Preconditioning matrix */
>                                void *ctxt    /*!< Application context */
>   PETScContext *context = (PETScContext*) ctxt;
>   HyPar        *solver  = context->solver;
>   _DECLARE_IERR_;
>   PetscFunctionBegin;
>   solver->count_IJacobian++;
>   context->shift = a;
>   context->waqt  = t;
>   /* Construct preconditioning matrix */
>   if (context->flag_use_precon) { IERR PetscComputePreconMatImpl(B,Y,context); CHECKERR(ierr); }
>   PetscFunctionReturn(0);
> and PetscJacobianFunction_JFNK which I bind to the matrix shell, computes the action of the jacobian on a vector : say U0 is the state of reference and Y the vector upon which to apply the JFNK method, then the PetscJacobianFunction_JFNK returns shift * Y - 1/epsilon * (F(U0 + epsilon*Y) - F(U0)) where F allows to evaluate the hyperbolic flux (shift comes from the TS).
> The preconditioning matrix I compute as an approximation to the actual jacobian, that is shift * Identity - Derivative(dF/dU) where dF/dU is, in each cell, a 4x4 matrix that is known exactly for the system of equations I am solving, i.e. Euler equations. For the structured grid, I can loop on the cells and do that 'Derivative' thing at first order by simply taking a finite-difference like approximation with the neighboring cells, Derivative(phi) = phi_i - phi_{i-1} and I assemble the B matrix block by block (JFunction is the dF/dU)
> /* diagonal element */
>  <>  for (v=0; v<nvars; v++) { rows[v] = nvars*pg + v; cols[v] = nvars*pg + v; }
>  <>  ierr = solver->JFunction <http://hypar.github.io/a00144.html#a25c87c7c874c7e08981688fe6c51167b>(values,(u+nvars*p),solver->physics <http://hypar.github.io/a00144.html#a48e81a1806b5774943fd9a26e9a190f2>,dir,0);
>  <>   _ArrayScale1D_ <http://hypar.github.io/a00165.html#a1dab5f429ccd03c4a7fbb605d8ef75b6>(values,(dxinv*iblank),(nvars*nvars));
>  <>   ierr = MatSetValues(Pmat,nvars,rows,nvars,cols,values,ADD_VALUES); CHKERRQ(ierr);
>  <>   /* left neighbor */
>  <>   if (pgL >= 0) {
>  <>   for (v=0; v<nvars; v++) { rows[v] = nvars*pg + v; cols[v] = nvars*pgL + v; }
>  <>   ierr = solver->JFunction <http://hypar.github.io/a00144.html#a25c87c7c874c7e08981688fe6c51167b>(values,(u+nvars*pL),solver->physics <http://hypar.github.io/a00144.html#a48e81a1806b5774943fd9a26e9a190f2>,dir,1);
>  <>   _ArrayScale1D_ <http://hypar.github.io/a00165.html#a1dab5f429ccd03c4a7fbb605d8ef75b6>(values,(-dxinv*iblank),(nvars*nvars));
>  <>   /* right neighbor */
>  <>   if (pgR >= 0) {
>  <>   for (v=0; v<nvars; v++) { rows[v] = nvars*pg + v; cols[v] = nvars*pgR + v; }
>  <>   ierr = solver->JFunction <http://hypar.github.io/a00144.html#a25c87c7c874c7e08981688fe6c51167b>(values,(u+nvars*pR),solver->physics <http://hypar.github.io/a00144.html#a48e81a1806b5774943fd9a26e9a190f2>,dir,-1);
> I do not know if I am clear here ...
> Anyways, I am trying to figure out how to do this shell matrix and this preconditioner using all the FV and DMPlex artillery.
> Okay, that is very clear. We should be able to get the JFNK just with -snes_mf_operator, and put the approximate J construction in DMPlexComputeJacobian_Internal().
> There is an FV section already, and we could just add this. I would need to understand those entries in the pointwise Riemann sense that the other stuff is now.
> Ok i had a quick look and if I understood correctly it would do the job. Setting the snes-mf-operator flag would mean however that we have to go through SNESSetJacobian to set the jacobian and the preconditioning matrix wouldn't it ?
  Thibault,
   Since the TS implicit methods end up using SNES internally the option should be available to you without requiring you to be calling the SNES routines directly
   Once you have finalized your approach and if for the implicit case you always work in the snes mf operator mode you can hardwire
    TSGetSNES(ts,&snes);
    SNESSetUseMatrixFree(snes,PETSC_TRUE,PETSC_FALSE);
    in your code so you don't need to always provide the option -snes-mf-operator
   Barry
> There might be calls to the Riemann solver to evaluate the dRHS / dU part yes but maybe it's possible to re-use what was computed for the RHS^n ?
> In the FV section the jacobian is set to identity which I missed before, but it could explain why when I used the following :
> TSSetType(ts, TSBEULER);
> DMTSSetIFunctionLocal(dm, DMPlexTSComputeIFunctionFEM <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/TS/DMPlexTSComputeIFunctionFEM.html#DMPlexTSComputeIFunctionFEM>, &ctx);
> DMTSSetIJacobianLocal(dm, DMPlexTSComputeIJacobianFEM <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/TS/DMPlexTSComputeIJacobianFEM.html#DMPlexTSComputeIJacobianFEM>, &ctx);
>  with my FV discretization nothing happened, right ?
> Thank you,
> Thibault
>   Thanks,
>      Matt
> Le ven. 21 août 2020 à 14:55, Thibault Bridel-Bertomeu <thibault.bridelbertomeu at gmail.com <mailto:thibault.bridelbertomeu at gmail.com>> a écrit :
> Hi,
> Thanks Matthew and Jed for your input.
> I indeed envision an implicit solver in the sense Jed mentioned - Jiri Blazek's book is a nice intro to this concept.
> Matthew, I do not know exactly what to change right now because although I understand globally what the DMPlexComputeXXXX_Internal methods do, I cannot say for sure line by line what is happening.
> In a structured code, I have a an implicit FVM solver with PETSc but I do not use any of the FV structure, not even a DM - I just use C arrays that I transform to PETSc Vec and Mat and build my IJacobian and my preconditioner and gives all that to a TS and it runs. I cannot figure out how to do it with the FV and the DM and all the underlying "shortcuts" that I want to use.
> Here is the top method for the structured code :
> int total_size = context.npoints * solver->nvars
>     ierr = TSSetRHSFunction(ts,PETSC_NULL,PetscRHSFunctionImpl,&context); CHKERRQ(ierr);
>     SNES     snes;
>     KSP      ksp;
>     PC       pc;
>     SNESType snestype;
>     ierr = TSGetSNES(ts,&snes); CHKERRQ(ierr);
>     ierr = SNESGetType(snes,&snestype); CHKERRQ(ierr);
>     flag_mat_a = 1;
>     ierr = MatCreateShell(MPI_COMM_WORLD,total_size,total_size,PETSC_DETERMINE,
>                           PETSC_DETERMINE,&context,&A); CHKERRQ(ierr);
>     context.jfnk_eps = 1e-7;
>     ierr = PetscOptionsGetReal(NULL,NULL,"-jfnk_epsilon",&context.jfnk_eps,NULL); CHKERRQ(ierr);
>     ierr = MatShellSetOperation(A,MATOP_MULT,(void (*)(void))PetscJacobianFunction_JFNK); CHKERRQ(ierr);
>     ierr = MatSetUp(A); CHKERRQ(ierr);
>     context.flag_use_precon = 0;
>     ierr = PetscOptionsGetBool(PETSC_NULL,PETSC_NULL,"-with_pc",(PetscBool*)(&context.flag_use_precon),PETSC_NULL); CHKERRQ(ierr);
>     /* Set up preconditioner matrix */
>     flag_mat_b = 1;
>     ierr = MatCreateAIJ(MPI_COMM_WORLD,total_size,total_size,PETSC_DETERMINE,PETSC_DETERMINE,
>                         (solver->ndims*2+1)*solver->nvars,NULL,
>                         2*solver->ndims*solver->nvars,NULL,&B); CHKERRQ(ierr);
>     ierr = MatSetBlockSize(B,solver->nvars);
>     /* Set the RHSJacobian function for TS */
>     ierr = TSSetIJacobian(ts,A,B,PetscIJacobian,&context); CHKERRQ(ierr);
>> Eng, MSc, PhD
> Research Engineer
> CEA/CESTA
> 33114 LE BARP
> Tel.: (+33)557046924
> Mob.: (+33)611025322
> Mail: thibault.bridelbertomeu at gmail.com <mailto:thibault.bridelbertomeu at gmail.com>
> Le jeu. 20 août 2020 à 18:43, Jed Brown <jed at jedbrown.org <mailto:jed at jedbrown.org>> a écrit :
> Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com>> writes:
> > I could never get the FVM stuff to make sense to me for implicit methods.
> > Here is my problem understanding. If you have an FVM method, it decides
> > to move "stuff" from one cell to its neighboring cells depending on the
> > solution to the Riemann problem on each face, which computed the flux. This
> > is
> > fine unless the timestep is so big that material can flow through into the
> > cells beyond the neighbor. Then I should have considered the effect of the
> > Riemann problem for those interfaces. That would be in the Jacobian, but I
> > don't know how to compute that Jacobian. I guess you could do everything
> > matrix-free, but without a preconditioner it seems hard.
> So long as we're using method of lines, the flux is just instantaneous flux, not integrated over some time step.  It has the same meaning for implicit and explicit.
> An explicit method would be unstable if you took such a large time step (CFL) and an implicit method will not simultaneously be SSP and higher than first order, but it's still a consistent discretization of the problem.
> It's common (done in FUN3D and others) to precondition with a first-order method, where gradient reconstruction/limiting is skipped.  That's what I'd recommend because limiting creates nasty nonlinearities and the resulting discretizations lack h-ellipticity which makes them very hard to solve.
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200821/c15ddd6e/attachment-0001.html>
