[petsc-users] Code (possibly) not running on GPU with CUDA
GIBB Gordon g.gibb at epcc.ed.ac.uk
Wed Aug 5 11:47:31 CDT 2020
Hi Matt,
It runs, however it doesn’t produce any output, and I have no way of checking to see if it actually ran on the GPU. It was run with:
srun -n 1 ./ex28 -vec_type cuda -use_gpu_aware_mpi 0
Cheers,
Gordon
Dr Gordon P S Gibb
EPCC, The University of Edinburgh
Tel: +44 131 651 3459
On 5 Aug 2020, at 17:10, Matthew Knepley <knepley at gmail.com<mailto:knepley at gmail.com>> wrote:
On Wed, Aug 5, 2020 at 11:24 AM GIBB Gordon <g.gibb at epcc.ed.ac.uk<mailto:g.gibb at epcc.ed.ac.uk>> wrote:
I’ve built PETSc with NVIDIA support for our GPU machine (https://cirrus.readthedocs.io/en/master/user-guide/gpu.html), and then compiled our executable against this PETSc (using version 3.13.3). I should add that the MPI on our system is not GPU-aware so I have to use -use_gpu_aware_mpi 0
When running this, in the .petscrc I put
-dm_vec_type cuda
-dm_mat_type aijcusparse
as is suggested on the PETSc GPU page (https://www.mcs.anl.gov/petsc/features/gpus.html) to enable CUDA for DMs (all our PETSc data structures are with DMs). I have also ensured I'm using the jacobi preconditioner so that it definitely runs on the GPU (again, according to the PETSc GPU page).
When I run this, I note that the GPU seems to have memory allocated on it from my executable, however seems to be doing no computation:
Wed Aug  5 13:10:23 2020
| NVIDIA-SMI 440.64.00    Driver Version: 440.64.00    CUDA Version: 10.2     |
| GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
|   0  Tesla V100-SXM2...  On   | 00000000:1A:00.0 Off |                  Off |
| N/A   43C    P0    64W / 300W |    490MiB / 16160MiB |      0%      Default |
| Processes:                                                       GPU Memory |
|  GPU       PID   Type   Process name                             Usage      |
|    0     33712      C   .../z04/gpsgibb/TPLS/TPLS-GPU/./twophase.x   479MiB |
I then ran the same example but without the -dm_vec_type cuda, -dm_mat_type aijcusparse arguments, and I found the same behaviour (479MB allocated on the GPU, 0% GPU utilisation).
In both cases the runtime of the example are near identical, suggesting that both are essentially the same run.
As a further test I compiled PETSc without CUDA support and ran the same example again, and found the same runtime as with the GPUs, and (as expected) no GPU memory allocated. I then tried to run the example with the -dm_vec_type cuda, -dm_mat_type aijcusparse arguments and it ran without complaint. I would have expected it to throw an error or at least a warning if invalid arguments were passed to it.
All this suggests to me that PETSc is ignoring my requests to use the GPUs. For the GPU-aware PETSc it seems to allocate memory on the GPUs but perform no calculations on them, regardless of whether I requested it to use the GPUs or not. On non-GPU-aware PETSc it accepts my requests to use the GPUs, but does not throw an error.
What am I doing wrong?
Lets step back to a simpler thing so we can make sure your configuration is correct. Can you run the 2_cuda test from
src/vec/vec/tests/ex28.c ? Does it execute on your GPU?
    Matt
Thanks in advance,
Gordon
Dr Gordon P S Gibb
The University of Edinburgh is a charitable body, registered in Scotland, with registration number SC005336.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/<http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200805/5865715e/attachment-0001.html>
