[petsc-users] Code (possibly) not running on GPU with CUDA
Matthew Knepley
knepley at gmail.com
Wed Aug 5 11:10:44 CDT 2020
On Wed, Aug 5, 2020 at 11:24 AM GIBB Gordon <g.gibb at epcc.ed.ac.uk> wrote:
> Hi,
> I’ve built PETSc with NVIDIA support for our GPU machine (
> https://cirrus.readthedocs.io/en/master/user-guide/gpu.html), and then
> compiled our executable against this PETSc (using version 3.13.3). I should
> add that the MPI on our system is not GPU-aware so I have to use -use_gpu_aware_mpi
> 0
> When running this, in the .petscrc I put
> -dm_vec_type cuda
> -dm_mat_type aijcusparse
> as is suggested on the PETSc GPU page (
> https://www.mcs.anl.gov/petsc/features/gpus.html) to enable CUDA for DMs
> (all our PETSc data structures are with DMs). I have also ensured I'm using
> the jacobi preconditioner so that it definitely runs on the GPU (again,
> according to the PETSc GPU page).
> When I run this, I note that the GPU seems to have memory allocated on it
> from my executable, however seems to be doing no computation:
> Wed Aug 5 13:10:23 2020
> | NVIDIA-SMI 440.64.00 Driver Version: 440.64.00 CUDA Version: 10.2
> | GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr.
> ECC |
> | Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute
> M. |
> | 0 Tesla V100-SXM2... On | 00000000:1A:00.0 Off |
> Off |
> | N/A 43C P0 64W / 300W | 490MiB / 16160MiB | 0%
> Default |
> | Processes: GPU
> Memory |
> | GPU PID Type Process name Usage
> | 0 33712 C .../z04/gpsgibb/TPLS/TPLS-GPU/./twophase.x
> 479MiB |
> I then ran the same example but without the -dm_vec_type cuda,
> -dm_mat_type aijcusparse arguments, and I found the same behaviour (479MB
> allocated on the GPU, 0% GPU utilisation).
> In both cases the runtime of the example are near identical, suggesting
> that both are essentially the same run.
> As a further test I compiled PETSc without CUDA support and ran the same
> example again, and found the same runtime as with the GPUs, and (as
> expected) no GPU memory allocated. I then tried to run the example with the -dm_vec_type
> cuda, -dm_mat_type aijcusparse arguments and it ran without complaint. I
> would have expected it to throw an error or at least a warning if invalid
> arguments were passed to it.
> All this suggests to me that PETSc is ignoring my requests to use the
> GPUs. For the GPU-aware PETSc it seems to allocate memory on the GPUs but
> perform no calculations on them, regardless of whether I requested it to
> use the GPUs or not. On non-GPU-aware PETSc it accepts my requests to use
> the GPUs, but does not throw an error.
> What am I doing wrong?
Lets step back to a simpler thing so we can make sure your configuration is
correct. Can you run the 2_cuda test from
src/vec/vec/tests/ex28.c ? Does it execute on your GPU?
Matt
> Thanks in advance,
> Gordon
> Dr Gordon P S Gibb
> EPCC, The University of Edinburgh
> Tel: +44 131 651 3459
> The University of Edinburgh is a charitable body, registered in Scotland,
> with registration number SC005336.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200805/ca243071/attachment.html>
