[petsc-users] Code (possibly) not running on GPU with CUDA
Wed Aug 5 11:58:16 CDT 2020
On Wed, Aug 5, 2020 at 12:47 PM GIBB Gordon <g.gibb at epcc.ed.ac.uk> wrote:
> Hi Matt,
> It runs, however it doesn’t produce any output, and I have no way of
> checking to see if it actually ran on the GPU. It was run with:
> srun -n 1 ./ex28 -vec_type cuda -use_gpu_aware_mpi 0
1) How did you check last time?
2) You can check using -log_view
     Matt
> Cheers,
> Gordon
> Dr Gordon P S Gibb
> EPCC, The University of Edinburgh
> Tel: +44 131 651 3459
> On 5 Aug 2020, at 17:10, Matthew Knepley <knepley at gmail.com> wrote:
> On Wed, Aug 5, 2020 at 11:24 AM GIBB Gordon <g.gibb at epcc.ed.ac.uk> wrote:
>> Hi,
>> I’ve built PETSc with NVIDIA support for our GPU machine (
>> https://cirrus.readthedocs.io/en/master/user-guide/gpu.html), and then
>> compiled our executable against this PETSc (using version 3.13.3). I should
>> add that the MPI on our system is not GPU-aware so I have to use -use_gpu_aware_mpi
>> 0
>> When running this, in the .petscrc I put
>> -dm_vec_type cuda
>> -dm_mat_type aijcusparse
>> as is suggested on the PETSc GPU page (
>> https://www.mcs.anl.gov/petsc/features/gpus.html) to enable CUDA for DMs
>> (all our PETSc data structures are with DMs). I have also ensured I'm using
>> the jacobi preconditioner so that it definitely runs on the GPU (again,
>> according to the PETSc GPU page).
>> When I run this, I note that the GPU seems to have memory allocated on it
>> from my executable, however seems to be doing no computation:
>> Wed Aug  5 13:10:23 2020
>> | NVIDIA-SMI 440.64.00    Driver Version: 440.64.00    CUDA Version: 10.2
>> | GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr.
>> ECC |
>> | Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util
>> Compute M. |
>> |   0  Tesla V100-SXM2...  On   | 00000000:1A:00.0 Off |
>> Off |
>> | N/A   43C    P0    64W / 300W |    490MiB / 16160MiB |      0%
>> Default |
>> | Processes:                                                       GPU
>> Memory |
>> |  GPU       PID   Type   Process name                             Usage
>> |    0     33712      C   .../z04/gpsgibb/TPLS/TPLS-GPU/./twophase.x
>> 479MiB |
>> I then ran the same example but without the -dm_vec_type cuda,
>> -dm_mat_type aijcusparse arguments, and I found the same behaviour (479MB
>> allocated on the GPU, 0% GPU utilisation).
>> In both cases the runtime of the example are near identical, suggesting
>> that both are essentially the same run.
>> As a further test I compiled PETSc without CUDA support and ran the same
>> example again, and found the same runtime as with the GPUs, and (as
>> expected) no GPU memory allocated. I then tried to run the example with the -dm_vec_type
>> cuda, -dm_mat_type aijcusparse arguments and it ran without complaint. I
>> would have expected it to throw an error or at least a warning if invalid
>> arguments were passed to it.
>> All this suggests to me that PETSc is ignoring my requests to use the
>> GPUs. For the GPU-aware PETSc it seems to allocate memory on the GPUs but
>> perform no calculations on them, regardless of whether I requested it to
>> use the GPUs or not. On non-GPU-aware PETSc it accepts my requests to use
>> the GPUs, but does not throw an error.
>> What am I doing wrong?
> Lets step back to a simpler thing so we can make sure your configuration
> is correct. Can you run the 2_cuda test from
> src/vec/vec/tests/ex28.c ? Does it execute on your GPU?
>   Thanks,
>     Matt
>> Thanks in advance,
>> Gordon
>> Dr Gordon P S Gibb
>> The University of Edinburgh is a charitable body, registered in Scotland,
>> with registration number SC005336.
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200805/0cdfc3ff/attachment.html>
