[petsc-users] [petsc-maint] petsc ksp solver hangs
Sat Sep 28 06:17:46 CDT 2019
What we want to see is the stack trace.
  Thanks
     Matt
On Sat, Sep 28, 2019, 06:33 Michael Wick via petsc-maint <
petsc-maint at mcs.anl.gov> wrote:
> I attached a debugger to my run. The code just hangs without throwing an
> error message, interestingly. I uses 72 processors. I turned on the ksp
> monitor. And I can see it hangs either at the beginning or the end of KSP
> iteration. I also uses valgrind to debug my code on my local machine, which
> does not detect any issue. I uses fgmres + fieldsplit, which is really a
> standard option.
> Do you have any suggestions to do?
> On Fri, Sep 27, 2019 at 8:17 PM Zhang, Junchao <jczhang at mcs.anl.gov>
> wrote:
>> How many MPI ranks did you use? If it is done on your desktop, you can
>> just attach a debugger to a MPI process to see what is going on.
>> --Junchao Zhang
>> On Fri, Sep 27, 2019 at 4:24 PM Michael Wick via petsc-maint <
>>> Hi PETSc:
>>> I have been experiencing a code stagnation at certain KSP iterations.
>>> This happens rather randomly, which means the code may stop at the middle
>>> of a KSP solve and hangs there.
>>> I have used valgrind and detect nothing. I just wonder if you have any
>>> suggestions.
>>> Thanks!!!
>>> M
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190928/845981b4/attachment.html>
