[petsc-users] [petsc-maint] petsc ksp solver hangs
Zhang, Junchao
jczhang at mcs.anl.gov
Sat Sep 28 08:22:43 CDT 2019
Does it hang with 2 or 4 processes? Which PETSc version do you use (using the latest is easier for us to debug)? Did you configure PETSc with --with-debugging=yes COPTFLAGS="-O0 -g" CXXOPTFLAGS="-O0 -g"
After attaching gdb to one process, you can use bt to see its stack trace.
--Junchao Zhang
On Sat, Sep 28, 2019 at 5:33 AM Michael Wick <michael.wick.1980 at gmail.com<mailto:michael.wick.1980 at gmail.com>> wrote:
I attached a debugger to my run. The code just hangs without throwing an error message, interestingly. I uses 72 processors. I turned on the ksp monitor. And I can see it hangs either at the beginning or the end of KSP iteration. I also uses valgrind to debug my code on my local machine, which does not detect any issue. I uses fgmres + fieldsplit, which is really a standard option.
Do you have any suggestions to do?
On Fri, Sep 27, 2019 at 8:17 PM Zhang, Junchao <jczhang at mcs.anl.gov<mailto:jczhang at mcs.anl.gov>> wrote:
How many MPI ranks did you use? If it is done on your desktop, you can just attach a debugger to a MPI process to see what is going on.
--Junchao Zhang
On Fri, Sep 27, 2019 at 4:24 PM Michael Wick via petsc-maint <petsc-maint at mcs.anl.gov<mailto:petsc-maint at mcs.anl.gov>> wrote:
Hi PETSc:
I have been experiencing a code stagnation at certain KSP iterations. This happens rather randomly, which means the code may stop at the middle of a KSP solve and hangs there.
I have used valgrind and detect nothing. I just wonder if you have any suggestions.
Thanks!!!
M
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190928/f8ca538c/attachment.html>
