[petsc-users] question about installing petsc3.11
Povolotskyi, Mykhailo
mpovolot at purdue.edu
Fri Sep 20 15:06:24 CDT 2019
I have to apologize.
By mistake I was installing the new version in the directory where the
old version already existed. After I cleaned everything, I do not see
that error message anymore.
Yes, the error message was somewhat misleading, but I will not be able
to reproduce it.
Michael.
On 09/20/2019 03:53 PM, Balay, Satish wrote:
> --with-64-bit-indices=1 => PetscInt = int64_t
> --known-64-bit-blas-indices=1 => blas specified uses 64bit indices.
> What is your requirement (use case)?
> Satish
> On Fri, 20 Sep 2019, Povolotskyi, Mykhailo via petsc-users wrote:
>> Does it mean I have to configure petsc with --with-64-bit-indices=1 ?
>> On 09/20/2019 03:41 PM, Matthew Knepley wrote:
>> On Fri, Sep 20, 2019 at 1:55 PM Povolotskyi, Mykhailo via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
>> Hello,
>> I'm upgrading petsc from 3.8 to 3.11.
>> In doing so, I see an error message:
>> UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for details):
>> Cannot use SuperLU_DIST with 64 bit BLAS/Lapack indices
>> I wonder why this configuration step worked well for 3.8? I did not
>> change anything else but version of petsc.
>> This never worked. We are just checking now.
>> Thanks,
>> Matt
>> Thank you,
>> Michael.
>> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/<http://www.cse.buffalo.edu/%7Eknepley/>
