[petsc-users] question about installing petsc3.11
Balay, Satish
balay at mcs.anl.gov
Fri Sep 20 14:53:34 CDT 2019
--with-64-bit-indices=1 => PetscInt = int64_t
--known-64-bit-blas-indices=1 => blas specified uses 64bit indices.
What is your requirement (use case)?
Satish
On Fri, 20 Sep 2019, Povolotskyi, Mykhailo via petsc-users wrote:
> Does it mean I have to configure petsc with --with-64-bit-indices=1 ?
> On 09/20/2019 03:41 PM, Matthew Knepley wrote:
> On Fri, Sep 20, 2019 at 1:55 PM Povolotskyi, Mykhailo via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
> Hello,
> I'm upgrading petsc from 3.8 to 3.11.
> In doing so, I see an error message:
> UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for details):
> Cannot use SuperLU_DIST with 64 bit BLAS/Lapack indices
> I wonder why this configuration step worked well for 3.8? I did not
> change anything else but version of petsc.
> This never worked. We are just checking now.
> Thanks,
> Matt
> Thank you,
> Michael.
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/<http://www.cse.buffalo.edu/%7Eknepley/>
