[petsc-users] Reading in the full matrix in one process and then trying to solve in parallel with PETSc
Fri Sep 20 07:08:28 CDT 2019
On Fri, Sep 20, 2019 at 7:54 AM Bao Kai via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Hi,
> I understand that PETSc is not designed to be used this way, while I
> am wondering if someone have done something similar to this.
> We have the full matrix from a simulation and rhs vector. We would
> like to read in through PETSc in one process, then we use some
> partition functions to partition the matrix.
> Based on the partition information, we redistribute the matrix among
> the processes. Then we solve it in parallel.  It is for testing the
> performance of some parallel linear solver and preconditions.
> We are not in the position to develop a full parallel implementation
> of the simulator yet.
This is not hard to do.
1) Write a simple serial converter that reads in your matrix in whatever
format you have it, and output it in PETSc Binary format
     using MatView() with a binary viewer. Same for the vector, and they
can be in the same file.
2) Run your parallel code and use MatLoad/VecLoad for the system and it
will automatically partition it.
     Matt
> Thanks.
> Cheers,
> Kai Bao
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190920/22313915/attachment.html>
