[petsc-users] PETSc 3.12 with .f90 files
Matthew Knepley
knepley at gmail.com
Tue Oct 29 13:45:30 CDT 2019
On Tue, Oct 29, 2019 at 2:35 PM Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
> The problem is that this change DOES use the preprocessor on the f90
> file, does it not? We need a rule that does not use the preprocessor.
This change just calls the Fortran compiler on it. The compiler decides to
use the preprocessor based on the extension (I thought).
Matt
> Barry
> > On Oct 29, 2019, at 10:50 AM, Matthew Knepley via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
> > On Tue, Oct 29, 2019 at 11:38 AM Randall Mackie <rlmackie862 at gmail.com>
> wrote:
> > Hi Matt,
> > That worked and everything compiles correctly now.
> > Great.
> > https://gitlab.com/petsc/petsc/merge_requests/2236
> > Thanks,
> > Matt
> > Thanks,
> > Randy
> >> On Oct 29, 2019, at 8:29 AM, Matthew Knepley <knepley at gmail.com> wrote:
> >> On Tue, Oct 29, 2019 at 11:25 AM Randall Mackie <rlmackie862 at gmail.com>
> wrote:
> >> Correct, no preprocessing.
> >> Okay. I am not sure why it would have been remove, but you can try
> adding .f90 to lib/petsc/conf/ruls line 273
> >> and see if that fixes it.
> >> THanks,
> >> Matt
> >>> On Oct 29, 2019, at 8:24 AM, Matthew Knepley <knepley at gmail.com>
> wrote:
> >>> On Tue, Oct 29, 2019 at 10:54 AM Randall Mackie via petsc-users <
> >>> Dear PETSc users:
> >>> In our code, we have one or two small .f90 files that are part of the
> software, and they have always compiled without any issues with previous
> versions of PETSc, using standard PETSc make files.
> >>> However, starting with PETSc 3.12, they no longer compile.
> >>> Was there some reasons for this change and any suggestion as to how to
> deal with this?
> >>> My cursory look cannot find a compile rule for .f90, only .F90. Di you
> not want preprocessing on that file?
> >>> Thanks,
> >>> Matt
> >>> Thanks, Randy
> >>> What most experimenters take for granted before they begin their
> experiments lead.
> >>> -- Norbert Wiener
> >>> https://www.cse.buffalo.edu/~knepley/
> experiments lead.
> >> -- Norbert Wiener
> experiments lead.
> > -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191029/8acb54fa/attachment.html>
