[petsc-users] PETSc 3.12 with .f90 files
Smith, Barry F.
bsmith at mcs.anl.gov
Tue Oct 29 13:35:45 CDT 2019
The problem is that this change DOES use the preprocessor on the f90 file, does it not? We need a rule that does not use the preprocessor.
Barry
> On Oct 29, 2019, at 10:50 AM, Matthew Knepley via petsc-users <petsc-users at mcs.anl.gov> wrote:
> On Tue, Oct 29, 2019 at 11:38 AM Randall Mackie <rlmackie862 at gmail.com> wrote:
> Hi Matt,
> That worked and everything compiles correctly now.
> Great.
> https://gitlab.com/petsc/petsc/merge_requests/2236
> Thanks,
> Matt
> Thanks,
> Randy
>> On Oct 29, 2019, at 8:29 AM, Matthew Knepley <knepley at gmail.com> wrote:
>> On Tue, Oct 29, 2019 at 11:25 AM Randall Mackie <rlmackie862 at gmail.com> wrote:
>> Correct, no preprocessing.
>> Okay. I am not sure why it would have been remove, but you can try adding .f90 to lib/petsc/conf/ruls line 273
>> and see if that fixes it.
>> THanks,
>> Matt
>>> On Oct 29, 2019, at 8:24 AM, Matthew Knepley <knepley at gmail.com> wrote:
>>> On Tue, Oct 29, 2019 at 10:54 AM Randall Mackie via petsc-users <petsc-users at mcs.anl.gov> wrote:
>>> Dear PETSc users:
>>> In our code, we have one or two small .f90 files that are part of the software, and they have always compiled without any issues with previous versions of PETSc, using standard PETSc make files.
>>> However, starting with PETSc 3.12, they no longer compile.
>>> Was there some reasons for this change and any suggestion as to how to deal with this?
>>> My cursory look cannot find a compile rule for .f90, only .F90. Di you not want preprocessing on that file?
>>> Thanks,
>>> Matt
>>> Thanks, Randy
>>> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/
>> -- Norbert Wiener
> -- Norbert Wiener
