[petsc-users] PETSc 3.12 with .f90 files
Tue Oct 29 10:50:11 CDT 2019
On Tue, Oct 29, 2019 at 11:38 AM Randall Mackie <rlmackie862 at gmail.com>
wrote:
> Hi Matt,
> That worked and everything compiles correctly now.
Great.
  https://gitlab.com/petsc/petsc/merge_requests/2236
    Matt
> Thanks,
> Randy
> On Oct 29, 2019, at 8:29 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, Oct 29, 2019 at 11:25 AM Randall Mackie <rlmackie862 at gmail.com>
> wrote:
>> Correct, no preprocessing.
> Okay. I am not sure why it would have been remove, but you can try adding
> .f90 to lib/petsc/conf/ruls line 273
> and see if that fixes it.
>   THanks,
>     Matt
>> On Oct 29, 2019, at 8:24 AM, Matthew Knepley <knepley at gmail.com> wrote:
>> On Tue, Oct 29, 2019 at 10:54 AM Randall Mackie via petsc-users <
>> petsc-users at mcs.anl.gov> wrote:
>>> Dear PETSc users:
>>> In our code, we have one or two small .f90 files that are part of the
>>> software, and they have always compiled without any issues with previous
>>> versions of PETSc, using standard PETSc make files.
>>> However, starting with PETSc 3.12, they no longer compile.
>>> Was there some reasons for this change and any suggestion as to how to
>>> deal with this?
>> My cursory look cannot find a compile rule for .f90, only .F90. Di you
>> not want preprocessing on that file?
>>   Thanks,
>>     Matt
>>> Thanks, Randy
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191029/9eb7cf99/attachment-0001.html>
