[petsc-users] TS_SSP implementation for co-dependent variables
Manuel Valera mvalera-w at sdsu.edu
Wed Oct 9 18:04:29 CDT 2019
Sorry, I don't follow this last email, my spatial discretization is fixed,
the problem is caused by the choice of vertical coordinate, in this case
sigma, that calls for an integration of the hydrostatic pressure to correct
for the right velocities.
 I had RK3 working before and SSP is much more stable, i can use way bigger
DTs but then i get this asynchronous time integration. With RK3 I can
operate in the intermediate states and thus I can advance everything in
synchronization, but bigger DTs are not viable, it turns unstable quickly.
On Wed, Oct 9, 2019 at 3:58 PM Jed Brown <jed at jedbrown.org> wrote:
> Is it a problem with the spatial discretization or with the time
> discretization that you've been using thus far?  (This sort of problem
> can occur for either reason.)
> Note that an SSP method is merely "preserving" -- the spatial
> discretization needs to be strongly stable for an SSP method to preserve
> it.  It sounds like yours is not, so maybe there is no particular
> benefit to using SSP over any other method (but likely tighter time step
> restriction).
> Manuel Valera <mvalera-w at sdsu.edu> writes:
> > To correct for the deformation of the sigma coordinate grid... without
> this
> > correction the velocity become unphysical in the zones of high slope of
> the
> > grid. This is very specific of our model and probably will be solved by
> > updating the equations transformation, but that's not nearly close to
> > happening right now.
> >> > Thanks,
> >> > My time integration schemes are all explicit, sorry if this a very
> >> atypical
> >> > setup. This is similar to the barotropic splitting but not exactly, we
> >> > don't have free surface in the model, this is only to correct for
> sigma
> >> > coordinates deformations in the velocity field.
> >> > From how i see it this could be solved by obtaining the intermediate
> >> stages
> >> > and then updating them accordingly, is this not possible to do ?
> >> Why are you splitting if all components are explicit and not subcycled?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191009/104d17e4/attachment.html>
