[petsc-users] solve problem with pastix
hg hgbk2008 at gmail.com
Thu Nov 14 14:04:42 CST 2019
Hello
It turns out that hwloc is not installed on the cluster system that I'm
using. Without hwloc, pastix will run into the branch using
sched_setaffinity and caused error (see above at sopalin_thread.c). I'm not
able to understand and find a solution with sched_setaffinity so I think
enabling hwloc is an easier solution. Between, hwloc is recommended to
compile Pastix according to those threads:
https://gforge.inria.fr/forum/forum.php?thread_id=32824&forum_id=599&group_id=186
https://solverstack.gitlabpages.inria.fr/pastix/Bindings.html
hwloc is supported in PETSc so I assumed a clean and easy solution to
compile with --download-hwloc. I made some changes in
config/BuildSystem/config/packages/PaStiX.py to tell pastix to link to
hwloc:
self.hwloc          = framework.require('config.packages.hwloc',self)
if self.hwloc.found:
      g.write('CCPASTIX   := $(CCPASTIX) -DWITH_HWLOC
'+self.headers.toString(self.hwloc.include)+'\n')
      g.write('EXTRALIB   := $(EXTRALIB)
'+self.libraries.toString(self.hwloc.dlib)+'\n')
But it does not compile:
Possible ERROR while running linker: exit code 1
stderr:
/opt/petsc-dev/lib/libpastix.a(pastix.o): In function `pastix_task_init':
/home/hbui/sw2/petsc-dev/arch-linux2-cxx-opt/externalpackages/pastix_5.2.3/src/sopalin/src/pastix.c:822:
undefined reference to `hwloc_topology_init'
/home/hbui/sw2/petsc-dev/arch-linux2-cxx-opt/externalpackages/pastix_5.2.3/src/sopalin/src/pastix.c:828:
undefined reference to `hwloc_topology_load'
/opt/petsc-dev/lib/libpastix.a(pastix.o): In function `pastix_task_clean':
/home/hbui/sw2/petsc-dev/arch-linux2-cxx-opt/externalpackages/pastix_5.2.3/src/sopalin/src/pastix.c:4677:
undefined reference to `hwloc_topology_destroy'
/opt/petsc-dev/lib/libpastix.a(sopalin_thread.o): In function
`hwloc_get_obj_by_type':
/opt/petsc-dev/include/hwloc/inlines.h:76: undefined reference to
`hwloc_get_type_depth'
/opt/petsc-dev/include/hwloc/inlines.h:81: undefined reference to
`hwloc_get_obj_by_depth'
`sopalin_bindthread':
/home/hbui/sw2/petsc-dev/arch-linux2-cxx-opt/externalpackages/pastix_5.2.3/src/sopalin/src/sopalin_thread.c:538:
undefined reference to `hwloc_bitmap_dup'
/home/hbui/sw2/petsc-dev/arch-linux2-cxx-opt/externalpackages/pastix_5.2.3/src/sopalin/src/sopalin_thread.c:539:
undefined reference to `hwloc_bitmap_singlify'
/home/hbui/sw2/petsc-dev/arch-linux2-cxx-opt/externalpackages/pastix_5.2.3/src/sopalin/src/sopalin_thread.c:543:
undefined reference to `hwloc_set_cpubind'
/home/hbui/sw2/petsc-dev/arch-linux2-cxx-opt/externalpackages/pastix_5.2.3/src/sopalin/src/sopalin_thread.c:567:
undefined reference to `hwloc_bitmap_free'
/home/hbui/sw2/petsc-dev/arch-linux2-cxx-opt/externalpackages/pastix_5.2.3/src/sopalin/src/sopalin_thread.c:548:
undefined reference to `hwloc_bitmap_asprintf'
Any idea is appreciated. I can attach configure.log as needed.
Giang
On Thu, Nov 7, 2019 at 12:18 AM hg <hgbk2008 at gmail.com> wrote:
> Hi Barry
> Maybe you're right, sched_setaffinity returns EINVAL in my case, Probably
> the scheduler does not allow the process to bind to thread on its own.
> Giang
> On Wed, Nov 6, 2019 at 4:52 PM Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
>>   You can also just look at configure.log where it will show the calling
>> sequence of how PETSc configured and built Pastix. The recipe is in
>> config/BuildSystem/config/packages/PaStiX.py we don't monkey with low level
>> things like the affinity of external packages. My guess is that your
>> cluster system has inconsistent parts related to this, that one tool works
>> and another does not indicates they are inconsistent with respect to each
>> other in what they expect.
>>    Barry
>> > On Nov 6, 2019, at 4:02 AM, Matthew Knepley <knepley at gmail.com> wrote:
>> > On Wed, Nov 6, 2019 at 4:40 AM hg <hgbk2008 at gmail.com> wrote:
>> > Look into
>> I saw something like:
>> > #ifdef HAVE_OLD_SCHED_SETAFFINITY
>> >     if(sched_setaffinity(0,&mask) < 0)
>> > #else /* HAVE_OLD_SCHED_SETAFFINITY */
>> >     if(sched_setaffinity(0,sizeof(mask),&mask) < 0)
>> > #endif /* HAVE_OLD_SCHED_SETAFFINITY */
>> >   perror("sched_setaffinity");
>> >   EXIT(MOD_SOPALIN, INTERNAL_ERR);
>> > Is there possibility that Petsc turn on HAVE_OLD_SCHED_SETAFFINITY
>> during compilation?
>> > May I know how to trigger re-compilation of external packages with
>> petsc? I may go in there and check what's going on.
>> > If we built it during configure, then you can just go to
>> >   $PETSC_DIR/$PETSC_ARCH/externalpackages/*pastix*/
>> > and rebuild/install it to test. If you want configure to do it, you
>> have to delete
>> >   $PETSC_DIR/$PETSC_ARCH/lib/petsc/conf/pkg.conf.pastix
>> > and reconfigure.
>> >   Thanks,
>> >      Matt
>> > Giang
>> > On Wed, Nov 6, 2019 at 10:12 AM hg <hgbk2008 at gmail.com> wrote:
>> > sched_setaffinity: Invalid argument only happens when I launch the job
>> with sbatch. Running without scheduler is fine. I think this has something
>> to do with pastix.
>> > Giang
>> > On Wed, Nov 6, 2019 at 4:37 AM Smith, Barry F. <bsmith at mcs.anl.gov>
>> wrote:
>> >   Google finds this
>> > > On Nov 5, 2019, at 7:01 PM, Matthew Knepley via petsc-users <
>> petsc-users at mcs.anl.gov> wrote:
>> > > I have no idea. That is a good question for the PasTix list.
>> > >   Thanks,
>> > >     Matt
>> > > On Tue, Nov 5, 2019 at 5:32 PM hg <hgbk2008 at gmail.com> wrote:
>> > > Should thread affinity be invoked? I set  -mat_pastix_threadnbr 1 and
>> also OMP_NUM_THREADS to 1
>> > > Giang
>> > > On Tue, Nov 5, 2019 at 10:50 PM Matthew Knepley <knepley at gmail.com>
>> wrote:
>> > > On Tue, Nov 5, 2019 at 4:11 PM hg via petsc-users <
>> > > Hello
>> > > I got crashed when using Pastix as solver for KSP. The error message
>> looks like:
>> > > NUMBER of BUBBLE 1
>> > > COEFMAX 1735566 CPFTMAX 0 BPFTMAX 0 NBFTMAX 0 ARFTMAX 0
>> > > ** End of Partition & Distribution phase **
>> > >    Time to analyze                              0.225 s
>> > >    Number of nonzeros in factorized matrix      708784076
>> > >    Fill-in                                      12.2337
>> > >    Number of operations (LU)                    2.80185e+12
>> > >    Prediction Time to factorize (AMD 6180  MKL) 394 s
>> > > 0 : SolverMatrix size (without coefficients)    32.4 MB
>> > > 0 : Number of nonzeros (local block structure)  365309391
>> > >  Numerical Factorization (LU) :
>> > > 0 : Internal CSC size                           1.08 GB
>> > >    Time to fill internal csc                    6.66 s
>> > >    --- Sopalin : Allocation de la structure globale ---
>> > >    --- Fin Sopalin Init                             ---
>> > >    --- Initialisation des tableaux globaux          ---
>> > > [node083:165071] *** Process received signal ***
>> > > [node083:165071] Signal: Aborted (6)
>> > > [node083:165071] Signal code:  (-6)
>> > > [node083:165071] [ 0] /lib64/libpthread.so.0(+0xf680)[0x2b8081845680]
>> > > [node083:165071] [ 1] /lib64/libc.so.6(gsignal+0x37)[0x2b8082191207]
>> > > [node083:165071] [ 2] /lib64/libc.so.6(abort+0x148)[0x2b80821928f8]
>> > > [node083:165071] [ 3]
>> /sdhome/bui/opt/petsc-3.11.0_ompi-3.0.0/lib/libpetsc.so.3.11(sopalin_launch_comm+0x0)[0x2b80a4124c9d]
>> > > [node083:165071] [ 4] Launching 1 threads (1 commputation, 0
>> communication, 0 out-of-core)
>> > >    --- Sopalin : Local structure allocation         ---
>> /sdhome/bui/opt/petsc-3.11.0_ompi-3.0.0/lib/libpetsc.so.3.11(D_sopalin_init_smp+0x29b)[0x2b80a40c39d2]
>> > > [node083:165071] [ 5]
>> /sdhome/bui/opt/petsc-3.11.0_ompi-3.0.0/lib/libpetsc.so.3.11(D_ge_sopalin_smp+0x68)[0x2b80a40cf4c2]
>> > > [node083:165071] [ 6]
>> /sdhome/bui/opt/petsc-3.11.0_ompi-3.0.0/lib/libpetsc.so.3.11(sopalin_launch_thread+0x4ba)[0x2b80a4124a31]
>> > > [node083:165071] [ 7]
>> /sdhome/bui/opt/petsc-3.11.0_ompi-3.0.0/lib/libpetsc.so.3.11(D_ge_sopalin_thread+0x94)[0x2b80a40d6170]
>> > > [node083:165071] [ 8]
>> /sdhome/bui/opt/petsc-3.11.0_ompi-3.0.0/lib/libpetsc.so.3.11(D_pastix_task_sopalin+0x5ad)[0x2b80a40b09a2]
>> > > [node083:165071] [ 9]
>> /sdhome/bui/opt/petsc-3.11.0_ompi-3.0.0/lib/libpetsc.so.3.11(d_pastix+0xa8a)[0x2b80a40b2325]
>> > > [node083:165071] [10]
>> /sdhome/bui/opt/petsc-3.11.0_ompi-3.0.0/lib/libpetsc.so.3.11(+0x63927b)[0x2b80a35bf27b]
>> > > [node083:165071] [11]
>> /sdhome/bui/opt/petsc-3.11.0_ompi-3.0.0/lib/libpetsc.so.3.11(MatLUFactorNumeric+0x19a)[0x2b80a32c7552]
>> > > [node083:165071] [12]
>> /sdhome/bui/opt/petsc-3.11.0_ompi-3.0.0/lib/libpetsc.so.3.11(+0xa46c09)[0x2b80a39ccc09]
>> > > [node083:165071] [13]
>> /sdhome/bui/opt/petsc-3.11.0_ompi-3.0.0/lib/libpetsc.so.3.11(PCSetUp+0x311)[0x2b80a3a8f1a9]
>> > > [node083:165071] [14]
>> /sdhome/bui/opt/petsc-3.11.0_ompi-3.0.0/lib/libpetsc.so.3.11(KSPSetUp+0xbf7)[0x2b80a3b46e81]
>> > > [node083:165071] [15]
>> /sdhome/bui/opt/petsc-3.11.0_ompi-3.0.0/lib/libpetsc.so.3.11(KSPSolve+0x210)[0x2b80a3b4746e]
>> > > Does anyone have an idea what is the problem and how to fix it? The
>> PETSc parameters I used are as below:
>> > > It looks like PasTix is having trouble setting the thread affinity:
>> > > so it may be your build of PasTix.
>> > >   Thanks,
>> > >      Matt
>> > > -pc_type lu
>> > > -pc_factor_mat_solver_package pastix
>> > > -mat_pastix_verbose 2
>> > > Giang
>> > > What most experimenters take for granted before they begin their
>> experiments lead.
>> > > -- Norbert Wiener
>> > > https://www.cse.buffalo.edu/~knepley/
>> experiments lead.
>> > > -- Norbert Wiener
>> experiments lead.
>> > -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191114/2fb491ff/attachment.html>
