[petsc-users] solve problem with pastix
hg hgbk2008 at gmail.com
Fri Nov 15 08:34:48 CST 2019
FYI, this problem is fixed, providing that hwloc is added to dependencies
of Pastix.
Giang
On Thu, Nov 14, 2019 at 9:04 PM hg <hgbk2008 at gmail.com> wrote:
> Hello
> It turns out that hwloc is not installed on the cluster system that I'm
> using. Without hwloc, pastix will run into the branch using
> sched_setaffinity and caused error (see above at sopalin_thread.c). I'm not
> able to understand and find a solution with sched_setaffinity so I think
> enabling hwloc is an easier solution. Between, hwloc is recommended to
> compile Pastix according to those threads:
> https://gforge.inria.fr/forum/forum.php?thread_id=32824&forum_id=599&group_id=186
> https://solverstack.gitlabpages.inria.fr/pastix/Bindings.html
> hwloc is supported in PETSc so I assumed a clean and easy solution to
> compile with --download-hwloc. I made some changes in
> config/BuildSystem/config/packages/PaStiX.py to tell pastix to link to
> hwloc:
> self.hwloc          = framework.require('config.packages.hwloc',self)
> if self.hwloc.found:
>       g.write('CCPASTIX   := $(CCPASTIX) -DWITH_HWLOC
> '+self.headers.toString(self.hwloc.include)+'\n')
>       g.write('EXTRALIB   := $(EXTRALIB)
> '+self.libraries.toString(self.hwloc.dlib)+'\n')
> But it does not compile:
> Possible ERROR while running linker: exit code 1
> stderr:
> /opt/petsc-dev/lib/libpastix.a(pastix.o): In function `pastix_task_init':
> /home/hbui/sw2/petsc-dev/arch-linux2-cxx-opt/externalpackages/pastix_5.2.3/src/sopalin/src/pastix.c:822:
> undefined reference to `hwloc_topology_init'
> /home/hbui/sw2/petsc-dev/arch-linux2-cxx-opt/externalpackages/pastix_5.2.3/src/sopalin/src/pastix.c:828:
> undefined reference to `hwloc_topology_load'
> /opt/petsc-dev/lib/libpastix.a(pastix.o): In function `pastix_task_clean':
> /home/hbui/sw2/petsc-dev/arch-linux2-cxx-opt/externalpackages/pastix_5.2.3/src/sopalin/src/pastix.c:4677:
> undefined reference to `hwloc_topology_destroy'
> /opt/petsc-dev/lib/libpastix.a(sopalin_thread.o): In function
> `hwloc_get_obj_by_type':
> /opt/petsc-dev/include/hwloc/inlines.h:76: undefined reference to
> `hwloc_get_type_depth'
> /opt/petsc-dev/include/hwloc/inlines.h:81: undefined reference to
> `hwloc_get_obj_by_depth'
> `sopalin_bindthread':
> /home/hbui/sw2/petsc-dev/arch-linux2-cxx-opt/externalpackages/pastix_5.2.3/src/sopalin/src/sopalin_thread.c:538:
> undefined reference to `hwloc_bitmap_dup'
> /home/hbui/sw2/petsc-dev/arch-linux2-cxx-opt/externalpackages/pastix_5.2.3/src/sopalin/src/sopalin_thread.c:539:
> undefined reference to `hwloc_bitmap_singlify'
> /home/hbui/sw2/petsc-dev/arch-linux2-cxx-opt/externalpackages/pastix_5.2.3/src/sopalin/src/sopalin_thread.c:543:
> undefined reference to `hwloc_set_cpubind'
> /home/hbui/sw2/petsc-dev/arch-linux2-cxx-opt/externalpackages/pastix_5.2.3/src/sopalin/src/sopalin_thread.c:567:
> undefined reference to `hwloc_bitmap_free'
> /home/hbui/sw2/petsc-dev/arch-linux2-cxx-opt/externalpackages/pastix_5.2.3/src/sopalin/src/sopalin_thread.c:548:
> undefined reference to `hwloc_bitmap_asprintf'
> Any idea is appreciated. I can attach configure.log as needed.
> Giang
> On Thu, Nov 7, 2019 at 12:18 AM hg <hgbk2008 at gmail.com> wrote:
>> Hi Barry
>> Maybe you're right, sched_setaffinity returns EINVAL in my case, Probably
>> the scheduler does not allow the process to bind to thread on its own.
>> Giang
>> On Wed, Nov 6, 2019 at 4:52 PM Smith, Barry F. <bsmith at mcs.anl.gov>
>> wrote:
>>>   You can also just look at configure.log where it will show the calling
>>> sequence of how PETSc configured and built Pastix. The recipe is in
>>> config/BuildSystem/config/packages/PaStiX.py we don't monkey with low level
>>> things like the affinity of external packages. My guess is that your
>>> cluster system has inconsistent parts related to this, that one tool works
>>> and another does not indicates they are inconsistent with respect to each
>>> other in what they expect.
>>>    Barry
>>> > On Nov 6, 2019, at 4:02 AM, Matthew Knepley <knepley at gmail.com> wrote:
>>> > On Wed, Nov 6, 2019 at 4:40 AM hg <hgbk2008 at gmail.com> wrote:
>>> > Look into
>>> I saw something like:
>>> > #ifdef HAVE_OLD_SCHED_SETAFFINITY
>>> >     if(sched_setaffinity(0,&mask) < 0)
>>> > #else /* HAVE_OLD_SCHED_SETAFFINITY */
>>> >     if(sched_setaffinity(0,sizeof(mask),&mask) < 0)
>>> > #endif /* HAVE_OLD_SCHED_SETAFFINITY */
>>> >   perror("sched_setaffinity");
>>> >   EXIT(MOD_SOPALIN, INTERNAL_ERR);
>>> > Is there possibility that Petsc turn on HAVE_OLD_SCHED_SETAFFINITY
>>> during compilation?
>>> > May I know how to trigger re-compilation of external packages with
>>> petsc? I may go in there and check what's going on.
>>> > If we built it during configure, then you can just go to
>>> >   $PETSC_DIR/$PETSC_ARCH/externalpackages/*pastix*/
>>> > and rebuild/install it to test. If you want configure to do it, you
>>> have to delete
>>> >   $PETSC_DIR/$PETSC_ARCH/lib/petsc/conf/pkg.conf.pastix
>>> > and reconfigure.
>>> >   Thanks,
>>> >      Matt
>>> > Giang
>>> > On Wed, Nov 6, 2019 at 10:12 AM hg <hgbk2008 at gmail.com> wrote:
>>> > sched_setaffinity: Invalid argument only happens when I launch the job
>>> with sbatch. Running without scheduler is fine. I think this has something
>>> to do with pastix.
>>> > Giang
>>> > On Wed, Nov 6, 2019 at 4:37 AM Smith, Barry F. <bsmith at mcs.anl.gov>
>>> wrote:
>>> >   Google finds this
>>> > > On Nov 5, 2019, at 7:01 PM, Matthew Knepley via petsc-users <
>>> petsc-users at mcs.anl.gov> wrote:
>>> > > I have no idea. That is a good question for the PasTix list.
>>> > >   Thanks,
>>> > >     Matt
>>> > > On Tue, Nov 5, 2019 at 5:32 PM hg <hgbk2008 at gmail.com> wrote:
>>> > > Should thread affinity be invoked? I set  -mat_pastix_threadnbr 1
>>> and also OMP_NUM_THREADS to 1
>>> > > Giang
>>> > > On Tue, Nov 5, 2019 at 10:50 PM Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>> > > On Tue, Nov 5, 2019 at 4:11 PM hg via petsc-users <
>>> > > Hello
>>> > > I got crashed when using Pastix as solver for KSP. The error message
>>> looks like:
>>> > > NUMBER of BUBBLE 1
>>> > > COEFMAX 1735566 CPFTMAX 0 BPFTMAX 0 NBFTMAX 0 ARFTMAX 0
>>> > > ** End of Partition & Distribution phase **
>>> > >    Time to analyze                              0.225 s
>>> > >    Number of nonzeros in factorized matrix      708784076
>>> > >    Fill-in                                      12.2337
>>> > >    Number of operations (LU)                    2.80185e+12
>>> > >    Prediction Time to factorize (AMD 6180  MKL) 394 s
>>> > > 0 : SolverMatrix size (without coefficients)    32.4 MB
>>> > > 0 : Number of nonzeros (local block structure)  365309391
>>> > >  Numerical Factorization (LU) :
>>> > > 0 : Internal CSC size                           1.08 GB
>>> > >    Time to fill internal csc                    6.66 s
>>> > >    --- Sopalin : Allocation de la structure globale ---
>>> > >    --- Fin Sopalin Init                             ---
>>> > >    --- Initialisation des tableaux globaux          ---
>>> > > [node083:165071] *** Process received signal ***
>>> > > [node083:165071] Signal: Aborted (6)
>>> > > [node083:165071] Signal code:  (-6)
>>> > > [node083:165071] [ 0] /lib64/libpthread.so.0(+0xf680)[0x2b8081845680]
>>> > > [node083:165071] [ 1] /lib64/libc.so.6(gsignal+0x37)[0x2b8082191207]
>>> > > [node083:165071] [ 2] /lib64/libc.so.6(abort+0x148)[0x2b80821928f8]
>>> > > [node083:165071] [ 3]
>>> /sdhome/bui/opt/petsc-3.11.0_ompi-3.0.0/lib/libpetsc.so.3.11(sopalin_launch_comm+0x0)[0x2b80a4124c9d]
>>> > > [node083:165071] [ 4] Launching 1 threads (1 commputation, 0
>>> communication, 0 out-of-core)
>>> > >    --- Sopalin : Local structure allocation         ---
>>> /sdhome/bui/opt/petsc-3.11.0_ompi-3.0.0/lib/libpetsc.so.3.11(D_sopalin_init_smp+0x29b)[0x2b80a40c39d2]
>>> > > [node083:165071] [ 5]
>>> /sdhome/bui/opt/petsc-3.11.0_ompi-3.0.0/lib/libpetsc.so.3.11(D_ge_sopalin_smp+0x68)[0x2b80a40cf4c2]
>>> > > [node083:165071] [ 6]
>>> /sdhome/bui/opt/petsc-3.11.0_ompi-3.0.0/lib/libpetsc.so.3.11(sopalin_launch_thread+0x4ba)[0x2b80a4124a31]
>>> > > [node083:165071] [ 7]
>>> /sdhome/bui/opt/petsc-3.11.0_ompi-3.0.0/lib/libpetsc.so.3.11(D_ge_sopalin_thread+0x94)[0x2b80a40d6170]
>>> > > [node083:165071] [ 8]
>>> /sdhome/bui/opt/petsc-3.11.0_ompi-3.0.0/lib/libpetsc.so.3.11(D_pastix_task_sopalin+0x5ad)[0x2b80a40b09a2]
>>> > > [node083:165071] [ 9]
>>> /sdhome/bui/opt/petsc-3.11.0_ompi-3.0.0/lib/libpetsc.so.3.11(d_pastix+0xa8a)[0x2b80a40b2325]
>>> > > [node083:165071] [10]
>>> /sdhome/bui/opt/petsc-3.11.0_ompi-3.0.0/lib/libpetsc.so.3.11(+0x63927b)[0x2b80a35bf27b]
>>> > > [node083:165071] [11]
>>> /sdhome/bui/opt/petsc-3.11.0_ompi-3.0.0/lib/libpetsc.so.3.11(MatLUFactorNumeric+0x19a)[0x2b80a32c7552]
>>> > > [node083:165071] [12]
>>> /sdhome/bui/opt/petsc-3.11.0_ompi-3.0.0/lib/libpetsc.so.3.11(+0xa46c09)[0x2b80a39ccc09]
>>> > > [node083:165071] [13]
>>> /sdhome/bui/opt/petsc-3.11.0_ompi-3.0.0/lib/libpetsc.so.3.11(PCSetUp+0x311)[0x2b80a3a8f1a9]
>>> > > [node083:165071] [14]
>>> /sdhome/bui/opt/petsc-3.11.0_ompi-3.0.0/lib/libpetsc.so.3.11(KSPSetUp+0xbf7)[0x2b80a3b46e81]
>>> > > [node083:165071] [15]
>>> /sdhome/bui/opt/petsc-3.11.0_ompi-3.0.0/lib/libpetsc.so.3.11(KSPSolve+0x210)[0x2b80a3b4746e]
>>> > > Does anyone have an idea what is the problem and how to fix it? The
>>> PETSc parameters I used are as below:
>>> > > It looks like PasTix is having trouble setting the thread affinity:
>>> > > so it may be your build of PasTix.
>>> > >   Thanks,
>>> > >      Matt
>>> > > -pc_type lu
>>> > > -pc_factor_mat_solver_package pastix
>>> > > -mat_pastix_verbose 2
>>> > > Giang
>>> > > What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> > > -- Norbert Wiener
>>> > > https://www.cse.buffalo.edu/~knepley/
>>> experiments lead.
>>> > > -- Norbert Wiener
>>> experiments lead.
>>> > -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191115/c8da2535/attachment.html>
