[petsc-users] solve problem with pastix
hg hgbk2008 at gmail.com
Wed Nov 6 17:18:18 CST 2019
Hi Barry
Maybe you're right, sched_setaffinity returns EINVAL in my case, Probably
the scheduler does not allow the process to bind to thread on its own.
Giang
On Wed, Nov 6, 2019 at 4:52 PM Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
>   You can also just look at configure.log where it will show the calling
> sequence of how PETSc configured and built Pastix. The recipe is in
> config/BuildSystem/config/packages/PaStiX.py we don't monkey with low level
> things like the affinity of external packages. My guess is that your
> cluster system has inconsistent parts related to this, that one tool works
> and another does not indicates they are inconsistent with respect to each
> other in what they expect.
>    Barry
> > On Nov 6, 2019, at 4:02 AM, Matthew Knepley <knepley at gmail.com> wrote:
> > On Wed, Nov 6, 2019 at 4:40 AM hg <hgbk2008 at gmail.com> wrote:
> > Look into
> arch-linux2-cxx-opt/externalpackages/pastix_5.2.3/src/sopalin/src/sopalin_thread.c
> I saw something like:
> > #ifdef HAVE_OLD_SCHED_SETAFFINITY
> >     if(sched_setaffinity(0,&mask) < 0)
> > #else /* HAVE_OLD_SCHED_SETAFFINITY */
> >     if(sched_setaffinity(0,sizeof(mask),&mask) < 0)
> > #endif /* HAVE_OLD_SCHED_SETAFFINITY */
> >   perror("sched_setaffinity");
> >   EXIT(MOD_SOPALIN, INTERNAL_ERR);
> > Is there possibility that Petsc turn on HAVE_OLD_SCHED_SETAFFINITY
> during compilation?
> > May I know how to trigger re-compilation of external packages with
> petsc? I may go in there and check what's going on.
> > If we built it during configure, then you can just go to
> >   $PETSC_DIR/$PETSC_ARCH/externalpackages/*pastix*/
> > and rebuild/install it to test. If you want configure to do it, you have
> to delete
> >   $PETSC_DIR/$PETSC_ARCH/lib/petsc/conf/pkg.conf.pastix
> > and reconfigure.
> >   Thanks,
> >      Matt
> > Giang
> > On Wed, Nov 6, 2019 at 10:12 AM hg <hgbk2008 at gmail.com> wrote:
> > sched_setaffinity: Invalid argument only happens when I launch the job
> with sbatch. Running without scheduler is fine. I think this has something
> to do with pastix.
> > Giang
> > On Wed, Nov 6, 2019 at 4:37 AM Smith, Barry F. <bsmith at mcs.anl.gov>
> wrote:
> >   Google finds this
> https://gforge.inria.fr/forum/forum.php?thread_id=32824&forum_id=599&group_id=186
> > > On Nov 5, 2019, at 7:01 PM, Matthew Knepley via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
> > > I have no idea. That is a good question for the PasTix list.
> > >   Thanks,
> > >     Matt
> > > On Tue, Nov 5, 2019 at 5:32 PM hg <hgbk2008 at gmail.com> wrote:
> > > Should thread affinity be invoked? I set  -mat_pastix_threadnbr 1 and
> also OMP_NUM_THREADS to 1
> > > Giang
> > > On Tue, Nov 5, 2019 at 10:50 PM Matthew Knepley <knepley at gmail.com>
> wrote:
> > > On Tue, Nov 5, 2019 at 4:11 PM hg via petsc-users <
> > > Hello
> > > I got crashed when using Pastix as solver for KSP. The error message
> looks like:
> > > NUMBER of BUBBLE 1
> > > COEFMAX 1735566 CPFTMAX 0 BPFTMAX 0 NBFTMAX 0 ARFTMAX 0
> > > ** End of Partition & Distribution phase **
> > >    Time to analyze                              0.225 s
> > >    Number of nonzeros in factorized matrix      708784076
> > >    Fill-in                                      12.2337
> > >    Number of operations (LU)                    2.80185e+12
> > >    Prediction Time to factorize (AMD 6180  MKL) 394 s
> > > 0 : SolverMatrix size (without coefficients)    32.4 MB
> > > 0 : Number of nonzeros (local block structure)  365309391
> > >  Numerical Factorization (LU) :
> > > 0 : Internal CSC size                           1.08 GB
> > >    Time to fill internal csc                    6.66 s
> > >    --- Sopalin : Allocation de la structure globale ---
> > >    --- Fin Sopalin Init                             ---
> > >    --- Initialisation des tableaux globaux          ---
> > > [node083:165071] *** Process received signal ***
> > > [node083:165071] Signal: Aborted (6)
> > > [node083:165071] Signal code:  (-6)
> > > [node083:165071] [ 0] /lib64/libpthread.so.0(+0xf680)[0x2b8081845680]
> > > [node083:165071] [ 1] /lib64/libc.so.6(gsignal+0x37)[0x2b8082191207]
> > > [node083:165071] [ 2] /lib64/libc.so.6(abort+0x148)[0x2b80821928f8]
> > > [node083:165071] [ 3]
> /sdhome/bui/opt/petsc-3.11.0_ompi-3.0.0/lib/libpetsc.so.3.11(sopalin_launch_comm+0x0)[0x2b80a4124c9d]
> > > [node083:165071] [ 4] Launching 1 threads (1 commputation, 0
> communication, 0 out-of-core)
> > >    --- Sopalin : Local structure allocation         ---
> /sdhome/bui/opt/petsc-3.11.0_ompi-3.0.0/lib/libpetsc.so.3.11(D_sopalin_init_smp+0x29b)[0x2b80a40c39d2]
> > > [node083:165071] [ 5]
> /sdhome/bui/opt/petsc-3.11.0_ompi-3.0.0/lib/libpetsc.so.3.11(D_ge_sopalin_smp+0x68)[0x2b80a40cf4c2]
> > > [node083:165071] [ 6]
> /sdhome/bui/opt/petsc-3.11.0_ompi-3.0.0/lib/libpetsc.so.3.11(sopalin_launch_thread+0x4ba)[0x2b80a4124a31]
> > > [node083:165071] [ 7]
> /sdhome/bui/opt/petsc-3.11.0_ompi-3.0.0/lib/libpetsc.so.3.11(D_ge_sopalin_thread+0x94)[0x2b80a40d6170]
> > > [node083:165071] [ 8]
> /sdhome/bui/opt/petsc-3.11.0_ompi-3.0.0/lib/libpetsc.so.3.11(D_pastix_task_sopalin+0x5ad)[0x2b80a40b09a2]
> > > [node083:165071] [ 9]
> /sdhome/bui/opt/petsc-3.11.0_ompi-3.0.0/lib/libpetsc.so.3.11(d_pastix+0xa8a)[0x2b80a40b2325]
> > > [node083:165071] [10]
> /sdhome/bui/opt/petsc-3.11.0_ompi-3.0.0/lib/libpetsc.so.3.11(+0x63927b)[0x2b80a35bf27b]
> > > [node083:165071] [11]
> /sdhome/bui/opt/petsc-3.11.0_ompi-3.0.0/lib/libpetsc.so.3.11(MatLUFactorNumeric+0x19a)[0x2b80a32c7552]
> > > [node083:165071] [12]
> /sdhome/bui/opt/petsc-3.11.0_ompi-3.0.0/lib/libpetsc.so.3.11(+0xa46c09)[0x2b80a39ccc09]
> > > [node083:165071] [13]
> /sdhome/bui/opt/petsc-3.11.0_ompi-3.0.0/lib/libpetsc.so.3.11(PCSetUp+0x311)[0x2b80a3a8f1a9]
> > > [node083:165071] [14]
> /sdhome/bui/opt/petsc-3.11.0_ompi-3.0.0/lib/libpetsc.so.3.11(KSPSetUp+0xbf7)[0x2b80a3b46e81]
> > > [node083:165071] [15]
> /sdhome/bui/opt/petsc-3.11.0_ompi-3.0.0/lib/libpetsc.so.3.11(KSPSolve+0x210)[0x2b80a3b4746e]
> > > Does anyone have an idea what is the problem and how to fix it? The
> PETSc parameters I used are as below:
> > > It looks like PasTix is having trouble setting the thread affinity:
> > > so it may be your build of PasTix.
> > >   Thanks,
> > >      Matt
> > > -pc_type lu
> > > -pc_factor_mat_solver_package pastix
> > > -mat_pastix_verbose 2
> > > Giang
> > > What most experimenters take for granted before they begin their
> experiments lead.
> > > -- Norbert Wiener
> > > https://www.cse.buffalo.edu/~knepley/
> experiments lead.
> > > -- Norbert Wiener
> experiments lead.
> > -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191107/66318b2a/attachment.html>
