[petsc-users] Stop KSP if diverging
Wed May 29 05:31:48 CDT 2019
On Wed, May 29, 2019 at 3:07 AM Edoardo alinovi via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Dear PETSc friends,
> Hope you are doing all well.
> I have a quick question for you that I am not able to solve by my self.
> Time to time, while testing new code features, it happens that KSP diverges
> but it does not stop automatically and the iterations continue even after
> getting a NaN.
I think you want
https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/KSP/KSPSetErrorIfNotConverged.html
    Matt
> In the KSP setup I use the following instruction to set the divergence
> stopping criteria (div = 10000):
> call KSPSetTolerances(myksp,  rel_tol,  abs_tol, div,  itmax,  ierr)
> But is does not help. Looking into the documentation I have found also:
> KSPConvergedDefault <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/KSP/KSPConvergedDefault.html#KSPConvergedDefault>(KSP <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/KSP/KSP.html#KSP> ksp,PetscInt <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PetscInt.html#PetscInt> n,PetscReal <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PetscReal.html#PetscReal> rnorm,KSPConvergedReason <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/KSP/KSPConvergedReason.html#KSPConvergedReason> *reason,void *ctx)
> Which I am not calling in the code. Is this maybe the reason of my
> problem? If yes how can I use KSPConvergedDefault
> <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/KSP/KSPConvergedDefault.html#KSPConvergedDefault> in
> FORTRAN?
> Thanks,
> Edo
> Edoardo Alinovi, Ph.D.
> DICCA, Scuola Politecnica,
> Universita' degli Studi di Genova,
> 1, via Montallegro,
> 16145 Genova, Italy
> Email: edoardo.alinovi at dicca.unige.it
> Tel: +39 010 353 2540
> Website: https://www.edoardoalinovi.com/
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190529/442d0747/attachment.html>
