[petsc-users] Stop KSP if diverging
Edoardo alinovi edoardo.alinovi at gmail.com
Wed May 29 05:35:06 CDT 2019
Thanks Matthew,
Yes, I will give it a try thid evening.
Thak you very much!
On Wed, 29 May 2019, 11:32 Matthew Knepley, <knepley at gmail.com> wrote:
> On Wed, May 29, 2019 at 3:07 AM Edoardo alinovi via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
>> Dear PETSc friends,
>> Hope you are doing all well.
>> I have a quick question for you that I am not able to solve by my self.
>> Time to time, while testing new code features, it happens that KSP diverges
>> but it does not stop automatically and the iterations continue even after
>> getting a NaN.
> I think you want
> https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/KSP/KSPSetErrorIfNotConverged.html
>   Thanks,
>     Matt
>> In the KSP setup I use the following instruction to set the divergence
>> stopping criteria (div = 10000):
>> call KSPSetTolerances(myksp,  rel_tol,  abs_tol, div,  itmax,  ierr)
>> But is does not help. Looking into the documentation I have found also:
>> KSPConvergedDefault <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/KSP/KSPConvergedDefault.html#KSPConvergedDefault>(KSP <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/KSP/KSP.html#KSP> ksp,PetscInt <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PetscInt.html#PetscInt> n,PetscReal <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PetscReal.html#PetscReal> rnorm,KSPConvergedReason <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/KSP/KSPConvergedReason.html#KSPConvergedReason> *reason,void *ctx)
>> Which I am not calling in the code. Is this maybe the reason of my
>> problem? If yes how can I use KSPConvergedDefault
>> <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/KSP/KSPConvergedDefault.html#KSPConvergedDefault> in
>> FORTRAN?
>> Thanks,
>> Edo
>> Edoardo Alinovi, Ph.D.
>> DICCA, Scuola Politecnica,
>> Universita' degli Studi di Genova,
>> 1, via Montallegro,
>> 16145 Genova, Italy
>> Email: edoardo.alinovi at dicca.unige.it
>> Tel: +39 010 353 2540
>> Website: https://www.edoardoalinovi.com/
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190529/09af23b9/attachment.html>
