[petsc-users] Stop KSP if diverging
Edoardo alinovi
edoardo.alinovi at gmail.com
Wed May 29 02:06:33 CDT 2019
Dear PETSc friends,
Hope you are doing all well.
I have a quick question for you that I am not able to solve by my self.
Time to time, while testing new code features, it happens that KSP diverges
but it does not stop automatically and the iterations continue even after
getting a NaN.
In the KSP setup I use the following instruction to set the divergence
stopping criteria (div = 10000):
call KSPSetTolerances(myksp, rel_tol, abs_tol, div, itmax, ierr)
But is does not help. Looking into the documentation I have found also:
KSPConvergedDefault
<https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/KSP/KSPConvergedDefault.html#KSPConvergedDefault>(KSP
<https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/KSP/KSP.html#KSP>
ksp,PetscInt <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PetscInt.html#PetscInt>
n,PetscReal <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PetscReal.html#PetscReal>
rnorm,KSPConvergedReason
<https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/KSP/KSPConvergedReason.html#KSPConvergedReason>
*reason,void *ctx)
Which I am not calling in the code. Is this maybe the reason of my problem?
If yes how can I use KSPConvergedDefault
in
FORTRAN?
Edo
Edoardo Alinovi, Ph.D.
DICCA, Scuola Politecnica,
Universita' degli Studi di Genova,
1, via Montallegro,
16145 Genova, Italy
Email: edoardo.alinovi at dicca.unige.it
Tel: +39 010 353 2540
Website: https://www.edoardoalinovi.com/
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190529/d3fae2fa/attachment-0001.html>
