[petsc-users] With-batch (new) flags
Mark Adams mfadams at lbl.gov
Tue May 21 07:30:37 CDT 2019
On Tue, May 21, 2019 at 12:16 AM Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
>   Yes, this is totally my fault. By removing the help message it made
> configure treat the argument as a string hence '0' was true and you got the
> error message. For fblaslapack one should use -known-64-bit-blas-indices=0
> just as you did, I have pushed a fix to master
>   What kind of system is sunfire09.pppl.gov ? Surely a system that has a
> batch system provides its own good BLAS/LAPACK. You should use the ones on
> the machine, not fblaslapack. Using fblaslapack in this situation is like
> going to a fancy sit-down dinner but bringing your dessert from McDonalds.
We just want stuff to work. This machine is not well supported and we are
using MUMPS, so we just want PETSc to build and be correct.
Thanks
>   It may be possible to remove many (but not all) of the cases where
> -known-64-bit-blas-indices is needed (for example when MKL, fblaslapack,
> f2blaslapack or --download-openblas is used we we know if the library is 64
> bit indices and should set that without a need for a test or command line
> option. I'll look at it.
>   Barry
> > On May 20, 2019, at 3:50 PM, Balay, Satish via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
> > I'm not yet sure what the correct fix is - but the following change
> should get this going..
> > diff --git a/config/BuildSystem/config/packages/BlasLapack.py
> b/config/BuildSystem/config/packages/BlasLapack.py
> > index e0310da4b0..7355f1a369 100644
> > --- a/config/BuildSystem/config/packages/BlasLapack.py
> > +++ b/config/BuildSystem/config/packages/BlasLapack.py
> > @@ -42,7 +42,7 @@ class Configure(config.package.Package):
> >     help.addArgument('BLAS/LAPACK', '-with-lapack-lib=<libraries: e.g.
> [/Users/..../liblapack.a,...]>',nargs.ArgLibrary(None, None, 'Indicate the
> library(s) containing LAPACK'))
> '-with-blaslapack-suffix=<string>',nargs.ArgLibrary(None, None, 'Indicate a
> suffix for BLAS/LAPACK subroutine names.'))
> >     help.addArgument('BLAS/LAPACK', '-with-64-bit-blas-indices',
> nargs.ArgBool(None, 0, 'Try to use 64 bit integers for BLAS/LAPACK; will
> error if not available'))
> > -#    help.addArgument('BLAS/LAPACK',
> '-known-64-bit-blas-indices=<bool>', nargs.ArgBool(None, 0, 'Indicate if
> using 64 bit integer BLAS'))
> > +    help.addArgument('BLAS/LAPACK',
> >     return
> >   def getPrefix(self):
> > Satish
> > On Mon, 20 May 2019, Mark Adams via petsc-users wrote:
> >> On Mon, May 20, 2019 at 3:55 PM Balay, Satish <balay at mcs.anl.gov>
> wrote:
> >>> for ex:  ilp version of mkl is --known-64-bit-blas-indices=1 while lp
> mkl
> >>> is --known-64-bit-blas-indices=0
> >>> Default blas we normally use is --known-64-bit-blas-indices=0 [they
> don't
> >>> use 64bit indices]
> >> Humm, that is what Dylan (in the log that I sent). He is downloading
> blas
> >> and has --known-64-bit-blas-indices=0. Should this be correct?
> >>> Satish
> >>>> We are getting this failure. This a bit frustrating in that the first
> >>> error
> >>>> message "Must give a default value for known-mpi-shared-libraries.."
> OK,
> >>> I
> >>>> google it and find that =0 is suggested. That seemed to work. Then we
> >>> got a
> >>>> similar error about -known-64-bit-blas-indices. It was clear from the
> >>>> documentation what to use so we tried =0 and that failed (attached).
> This
> >>>> is little frustrating having to use try and error for each of these
> >>> 'known"
> >>>> things.
> >>>> Dylan is trying  --known-64-bit-blas-indices=1 now. I trust that will
> >>> work,
> >>>> but I think the error are not very informative. All this known stuff
> is
> >>> new
> >>>> to me. Perhaps put an FAQ for this and list all of the "known"s that
> we
> >>>> need to add in batch.
> >>>> Thanks,
> >>>> Mark
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190521/516f55ec/attachment.html>
