[petsc-users] With-batch (new) flags
Smith, Barry F. bsmith at mcs.anl.gov
Tue May 21 09:57:21 CDT 2019
  I have posted a pull request that will greatly reduce the need to use the -known-64-bit-blas-indices flag on batch systems. https://bitbucket.org/petsc/petsc/pull-requests/1689/reduce-the-need-to-automatically-detect-or/diff This includes your use case.
   Thanks for the complaint, it resulted in easier installs for some people in the future,
   Barry
> On May 21, 2019, at 7:30 AM, Mark Adams <mfadams at lbl.gov> wrote:
> On Tue, May 21, 2019 at 12:16 AM Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
>   Yes, this is totally my fault. By removing the help message it made configure treat the argument as a string hence '0' was true and you got the error message. For fblaslapack one should use -known-64-bit-blas-indices=0 just as you did, I have pushed a fix to master
>   What kind of system is sunfire09.pppl.gov ? Surely a system that has a batch system provides its own good BLAS/LAPACK. You should use the ones on the machine, not fblaslapack. Using fblaslapack in this situation is like going to a fancy sit-down dinner but bringing your dessert from McDonalds.
> We just want stuff to work. This machine is not well supported and we are using MUMPS, so we just want PETSc to build and be correct.
> Thanks
>   It may be possible to remove many (but not all) of the cases where -known-64-bit-blas-indices is needed (for example when MKL, fblaslapack, f2blaslapack or --download-openblas is used we we know if the library is 64 bit indices and should set that without a need for a test or command line option. I'll look at it.
>   Barry
> > On May 20, 2019, at 3:50 PM, Balay, Satish via petsc-users <petsc-users at mcs.anl.gov> wrote:
> > I'm not yet sure what the correct fix is - but the following change should get this going..
> > diff --git a/config/BuildSystem/config/packages/BlasLapack.py b/config/BuildSystem/config/packages/BlasLapack.py
> > index e0310da4b0..7355f1a369 100644
> > --- a/config/BuildSystem/config/packages/BlasLapack.py
> > +++ b/config/BuildSystem/config/packages/BlasLapack.py
> > @@ -42,7 +42,7 @@ class Configure(config.package.Package):
> >     help.addArgument('BLAS/LAPACK', '-with-lapack-lib=<libraries: e.g. [/Users/..../liblapack.a,...]>',nargs.ArgLibrary(None, None, 'Indicate the library(s) containing LAPACK'))
> >     help.addArgument('BLAS/LAPACK', '-with-blaslapack-suffix=<string>',nargs.ArgLibrary(None, None, 'Indicate a suffix for BLAS/LAPACK subroutine names.'))
> >     help.addArgument('BLAS/LAPACK', '-with-64-bit-blas-indices', nargs.ArgBool(None, 0, 'Try to use 64 bit integers for BLAS/LAPACK; will error if not available'))
> > -#    help.addArgument('BLAS/LAPACK', '-known-64-bit-blas-indices=<bool>', nargs.ArgBool(None, 0, 'Indicate if using 64 bit integer BLAS'))
> > +    help.addArgument('BLAS/LAPACK', '-known-64-bit-blas-indices=<bool>', nargs.ArgBool(None, 0, 'Indicate if using 64 bit integer BLAS'))
> >     return
> >   def getPrefix(self):
> > Satish
> > On Mon, 20 May 2019, Mark Adams via petsc-users wrote:
> >> On Mon, May 20, 2019 at 3:55 PM Balay, Satish <balay at mcs.anl.gov> wrote:
> >>> for ex:  ilp version of mkl is --known-64-bit-blas-indices=1 while lp mkl
> >>> is --known-64-bit-blas-indices=0
> >>> Default blas we normally use is --known-64-bit-blas-indices=0 [they don't
> >>> use 64bit indices]
> >> Humm, that is what Dylan (in the log that I sent). He is downloading blas
> >> and has --known-64-bit-blas-indices=0. Should this be correct?
> >>> Satish
> >>>> We are getting this failure. This a bit frustrating in that the first
> >>> error
> >>>> message "Must give a default value for known-mpi-shared-libraries.." OK,
> >>> I
> >>>> google it and find that =0 is suggested. That seemed to work. Then we
> >>> got a
> >>>> similar error about -known-64-bit-blas-indices. It was clear from the
> >>>> documentation what to use so we tried =0 and that failed (attached). This
> >>>> is little frustrating having to use try and error for each of these
> >>> 'known"
> >>>> things.
> >>>> Dylan is trying  --known-64-bit-blas-indices=1 now. I trust that will
> >>> work,
> >>>> but I think the error are not very informative. All this known stuff is
> >>> new
> >>>> to me. Perhaps put an FAQ for this and list all of the "known"s that we
> >>>> need to add in batch.
> >>>> Thanks,
> >>>> Mark
