[petsc-users] With-batch (new) flags
    Smith, Barry F.
    bsmith at mcs.anl.gov
    Mon May 20 23:15:57 CDT 2019
  Yes, this is totally my fault. By removing the help message it made configure treat the argument as a string hence '0' was true and you got the error message. For fblaslapack one should use -known-64-bit-blas-indices=0 just as you did, I have pushed a fix to master
  What kind of system is sunfire09.pppl.gov ? Surely a system that has a batch system provides its own good BLAS/LAPACK. You should use the ones on the machine, not fblaslapack. Using fblaslapack in this situation is like going to a fancy sit-down dinner but bringing your dessert from McDonalds.
  It may be possible to remove many (but not all) of the cases where -known-64-bit-blas-indices is needed (for example when MKL, fblaslapack, f2blaslapack or --download-openblas is used we we know if the library is 64 bit indices and should set that without a need for a test or command line option. I'll look at it.
  Barry
> On May 20, 2019, at 3:50 PM, Balay, Satish via petsc-users <petsc-users at mcs.anl.gov> wrote:
> I'm not yet sure what the correct fix is - but the following change should get this going..
> diff --git a/config/BuildSystem/config/packages/BlasLapack.py b/config/BuildSystem/config/packages/BlasLapack.py
> index e0310da4b0..7355f1a369 100644
> --- a/config/BuildSystem/config/packages/BlasLapack.py
> +++ b/config/BuildSystem/config/packages/BlasLapack.py
> @@ -42,7 +42,7 @@ class Configure(config.package.Package):
>     help.addArgument('BLAS/LAPACK', '-with-lapack-lib=<libraries: e.g. [/Users/..../liblapack.a,...]>',nargs.ArgLibrary(None, None, 'Indicate the library(s) containing LAPACK'))
>     help.addArgument('BLAS/LAPACK', '-with-blaslapack-suffix=<string>',nargs.ArgLibrary(None, None, 'Indicate a suffix for BLAS/LAPACK subroutine names.'))
>     help.addArgument('BLAS/LAPACK', '-with-64-bit-blas-indices', nargs.ArgBool(None, 0, 'Try to use 64 bit integers for BLAS/LAPACK; will error if not available'))
> -#    help.addArgument('BLAS/LAPACK', '-known-64-bit-blas-indices=<bool>', nargs.ArgBool(None, 0, 'Indicate if using 64 bit integer BLAS'))
> +    help.addArgument('BLAS/LAPACK', '-known-64-bit-blas-indices=<bool>', nargs.ArgBool(None, 0, 'Indicate if using 64 bit integer BLAS'))
>     return
>   def getPrefix(self):
> Satish
> On Mon, 20 May 2019, Mark Adams via petsc-users wrote:
>> On Mon, May 20, 2019 at 3:55 PM Balay, Satish <balay at mcs.anl.gov> wrote:
>>> for ex:  ilp version of mkl is --known-64-bit-blas-indices=1 while lp mkl
>>> is --known-64-bit-blas-indices=0
>>> Default blas we normally use is --known-64-bit-blas-indices=0 [they don't
>>> use 64bit indices]
>> Humm, that is what Dylan (in the log that I sent). He is downloading blas
>> and has --known-64-bit-blas-indices=0. Should this be correct?
>>> Satish
>>>> We are getting this failure. This a bit frustrating in that the first
>>> error
>>>> message "Must give a default value for known-mpi-shared-libraries.." OK,
>>> I
>>>> google it and find that =0 is suggested. That seemed to work. Then we
>>> got a
>>>> similar error about -known-64-bit-blas-indices. It was clear from the
>>>> documentation what to use so we tried =0 and that failed (attached). This
>>>> is little frustrating having to use try and error for each of these
>>> 'known"
>>>> things.
>>>> Dylan is trying  --known-64-bit-blas-indices=1 now. I trust that will
>>> work,
>>>> but I think the error are not very informative. All this known stuff is
>>> new
>>>> to me. Perhaps put an FAQ for this and list all of the "known"s that we
>>>> need to add in batch.
>>>> Thanks,
>>>> Mark
