[petsc-users] Solving block systems with some null diagonal blocks
Mon Mar 25 12:27:44 CDT 2019
On Mon, Mar 25, 2019 at 8:07 AM Manuel Colera Rico via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Hello,
> I would like to solve a N*N block system (with N>2) in which some of the
> diagonal blocks are null. My system matrix is defined as a MatNest. As
> N>2, I can't use "pc_fieldsplit_type schur" nor
> "pc_fieldsplit_detect_saddle_point". The other algorithms ("additive",
> "multiplicative" and "symmetric_multiplicative") don't work either as
> they need each A_ii to be non-zero.
> Is there any built-in function in PETSc for this? If not, could you
> please suggest a workaround?
You can just shove all of the rows with nonzero diagonal in one field, and
all with zero diagonal in another, and do Schur. This is what
  -pc_fieldsplit_detect_saddle_point
does. However, you have to understand the Schur complement to solve it
efficiently. More generally, you can recursively split the matrix,
which is what I do for many multiphysics problems.
    Matt
> Thanks and kind regards,
> Manuel
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190325/50fc48e1/attachment.html>
