[petsc-users] SLEPc Build Error
Jose E. Roman
jroman at dsic.upv.es
Tue Mar 19 05:46:09 CDT 2019
And what is in $SLEPC_DIR/arch-linux2-c-debug/lib/slepc/conf/configure.log ?
Jose
> El 19 mar 2019, a las 11:41, Eda Oktay via petsc-users <petsc-users at mcs.anl.gov> escribió:
> This is slepc.log:
> Checking environment... done
> Checking PETSc installation...
> ERROR: Unable to link with PETSc
> ERROR: See "arch-linux2-c-debug/lib/slepc/conf/configure.log" file for details
> Matthew Knepley <knepley at gmail.com>, 19 Mar 2019 Sal, 13:36 tarihinde şunu yazdı:
> On Tue, Mar 19, 2019 at 6:31 AM Eda Oktay via petsc-users <petsc-users at mcs.anl.gov> wrote:
> Hello,
> I am trying to install PETSc with following configure options:
> ./configure --download-openmpi --download-openblas --download-slepc --download-cmake --download-metis --download-parmetis
> Compilation is done but after the following command, I got an error:
> make PETSC_DIR=/home/slurm_local/e200781/petsc-3.10.4 PETSC_ARCH=arch-linux2-c-debug all
> *** Building slepc ***
> **************************ERROR*************************************
> Error building slepc. Check arch-linux2-c-debug/lib/petsc/conf/slepc.log
> We need slepc.log
> Thanks,
> Matt
> /home/slurm_local/e200781/petsc-3.10.4/arch-linux2-c-debug/lib/petsc/conf/petscrules:46: recipe for target 'slepcbuild' failed
> make[1]: *** [slepcbuild] Error 1
> make[1]: Leaving directory '/home/slurm_local/e200781/petsc-3.10.4'
> Error during compile, check arch-linux2-c-debug/lib/petsc/conf/make.log
> Send it and arch-linux2-c-debug/lib/petsc/conf/configure.log to petsc-maint at mcs.anl.gov
> makefile:30: recipe for target 'all' failed
> make: *** [all] Error 1
> How can I fix the problem?
> Thank you,
> Eda
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
