[petsc-users] SLEPc Build Error
Eda Oktay
eda.oktay at metu.edu.tr
Tue Mar 19 05:41:04 CDT 2019
This is slepc.log:
Checking environment... done
Checking PETSc installation...
ERROR: Unable to link with PETSc
ERROR: See "arch-linux2-c-debug/lib/slepc/conf/configure.log" file for
details
Matthew Knepley <knepley at gmail.com>, 19 Mar 2019 Sal, 13:36 tarihinde şunu
yazdı:
> On Tue, Mar 19, 2019 at 6:31 AM Eda Oktay via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
>> Hello,
>> I am trying to install PETSc with following configure options:
>> ./configure --download-openmpi --download-openblas --download-slepc
>> --download-cmake --download-metis --download-parmetis
>> Compilation is done but after the following command, I got an error:
>> make PETSC_DIR=/home/slurm_local/e200781/petsc-3.10.4
>> PETSC_ARCH=arch-linux2-c-debug all
>> *** Building slepc ***
>> **************************ERROR*************************************
>> Error building slepc. Check arch-linux2-c-debug/lib/petsc/conf/slepc.log
> We need slepc.log
> Thanks,
> Matt
>> /home/slurm_local/e200781/petsc-3.10.4/arch-linux2-c-debug/lib/petsc/conf/petscrules:46:
>> recipe for target 'slepcbuild' failed
>> make[1]: *** [slepcbuild] Error 1
>> make[1]: Leaving directory '/home/slurm_local/e200781/petsc-3.10.4'
>> Error during compile, check arch-linux2-c-debug/lib/petsc/conf/make.log
>> Send it and arch-linux2-c-debug/lib/petsc/conf/configure.log to
>> petsc-maint at mcs.anl.gov
>> makefile:30: recipe for target 'all' failed
>> make: *** [all] Error 1
>> How can I fix the problem?
>> Thank you,
>> Eda
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190319/fc6987fc/attachment.html>
