[petsc-users] SLEPc Build Error
Jose E. Roman jroman at dsic.upv.es
Tue Mar 19 05:49:39 CDT 2019
Correction: the correct path is $PETSC_DIR/$PETSC_ARCH/externalpackages/git.slepc/$PETSC_ARCH/lib/slepc/conf/configure.log
> El 19 mar 2019, a las 11:46, Jose E. Roman via petsc-users <petsc-users at mcs.anl.gov> escribió:
> And what is in $SLEPC_DIR/arch-linux2-c-debug/lib/slepc/conf/configure.log ?
> Jose
>> El 19 mar 2019, a las 11:41, Eda Oktay via petsc-users <petsc-users at mcs.anl.gov> escribió:
>> This is slepc.log:
>> Checking environment... done
>> Checking PETSc installation...
>> ERROR: Unable to link with PETSc
>> ERROR: See "arch-linux2-c-debug/lib/slepc/conf/configure.log" file for details
>> Matthew Knepley <knepley at gmail.com>, 19 Mar 2019 Sal, 13:36 tarihinde şunu yazdı:
>> On Tue, Mar 19, 2019 at 6:31 AM Eda Oktay via petsc-users <petsc-users at mcs.anl.gov> wrote:
>> Hello,
>> I am trying to install PETSc with following configure options:
>> ./configure --download-openmpi --download-openblas --download-slepc --download-cmake --download-metis --download-parmetis
>> Compilation is done but after the following command, I got an error:
>> make PETSC_DIR=/home/slurm_local/e200781/petsc-3.10.4 PETSC_ARCH=arch-linux2-c-debug all
>> *** Building slepc ***
>> **************************ERROR*************************************
>> Error building slepc. Check arch-linux2-c-debug/lib/petsc/conf/slepc.log
>> We need slepc.log
>>  Thanks,
>>     Matt
>> /home/slurm_local/e200781/petsc-3.10.4/arch-linux2-c-debug/lib/petsc/conf/petscrules:46: recipe for target 'slepcbuild' failed
>> make[1]: *** [slepcbuild] Error 1
>> make[1]: Leaving directory '/home/slurm_local/e200781/petsc-3.10.4'
>>  Error during compile, check arch-linux2-c-debug/lib/petsc/conf/make.log
>>  Send it and arch-linux2-c-debug/lib/petsc/conf/configure.log to petsc-maint at mcs.anl.gov
>> makefile:30: recipe for target 'all' failed
>> make: *** [all] Error 1
>> How can I fix the problem?
>> Thank you,
>> Eda
>> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
