[petsc-users] SLEPc Build Error
Tue Mar 19 05:36:06 CDT 2019
On Tue, Mar 19, 2019 at 6:31 AM Eda Oktay via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Hello,
> I am trying to install PETSc with following configure options:
> ./configure --download-openmpi --download-openblas --download-slepc
> --download-cmake --download-metis --download-parmetis
> Compilation is done but after the following command, I got an error:
> make PETSC_DIR=/home/slurm_local/e200781/petsc-3.10.4
> PETSC_ARCH=arch-linux2-c-debug all
> *** Building slepc ***
> **************************ERROR*************************************
> Error building slepc. Check arch-linux2-c-debug/lib/petsc/conf/slepc.log
We need slepc.log
     Matt
> /home/slurm_local/e200781/petsc-3.10.4/arch-linux2-c-debug/lib/petsc/conf/petscrules:46:
> recipe for target 'slepcbuild' failed
> make[1]: *** [slepcbuild] Error 1
> make[1]: Leaving directory '/home/slurm_local/e200781/petsc-3.10.4'
>   Error during compile, check arch-linux2-c-debug/lib/petsc/conf/make.log
>   Send it and arch-linux2-c-debug/lib/petsc/conf/configure.log to
> petsc-maint at mcs.anl.gov
> makefile:30: recipe for target 'all' failed
> make: *** [all] Error 1
> How can I fix the problem?
> Thank you,
> Eda
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190319/0f15d7d0/attachment.html>
