[petsc-users] SLEPc Build Error
Eda Oktay eda.oktay at metu.edu.tr
Tue Mar 19 05:31:29 CDT 2019
Hello,
I am trying to install PETSc with following configure options:
./configure --download-openmpi --download-openblas --download-slepc
--download-cmake --download-metis --download-parmetis
Compilation is done but after the following command, I got an error:
make PETSC_DIR=/home/slurm_local/e200781/petsc-3.10.4
PETSC_ARCH=arch-linux2-c-debug all
*** Building slepc ***
**************************ERROR*************************************
Error building slepc. Check arch-linux2-c-debug/lib/petsc/conf/slepc.log
/home/slurm_local/e200781/petsc-3.10.4/arch-linux2-c-debug/lib/petsc/conf/petscrules:46:
recipe for target 'slepcbuild' failed
make[1]: *** [slepcbuild] Error 1
make[1]: Leaving directory '/home/slurm_local/e200781/petsc-3.10.4'
  Error during compile, check arch-linux2-c-debug/lib/petsc/conf/make.log
  Send it and arch-linux2-c-debug/lib/petsc/conf/configure.log to
petsc-maint at mcs.anl.gov
makefile:30: recipe for target 'all' failed
make: *** [all] Error 1
How can I fix the problem?
Thank you,
Eda
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190319/cb57a6d1/attachment.html>
