[petsc-users] Error during install check - intel compiler
Smith, Barry F.
bsmith at mcs.anl.gov
Mon Mar 11 16:33:44 CDT 2019
Not good. Run the test manually, then in the debugger to see exactly where it is crashing.
cd src/snes/examples/tutorials
make ex19
./ex19
gdb (or the intel debugger) ./ex19
run
Send all the output
> On Mar 11, 2019, at 4:13 PM, Edoardo alinovi via petsc-users <petsc-users at mcs.anl.gov> wrote:
> Dear all,
> It's a while that I do not write here, hope you are doing all very well!
> I am compiling petsc with intel, everything seems fine druing configuration and make steps but when I perform the install check I get several errors (attached the log file). Are they dangerous (they are not very encouraging segmentation faults) ? What can I do to fix a bit the thing in the case?
> Configuration options are:
> ./configure PETSC_ARCH=arch-intel-opt --with-debugging=no --with-cxx-dialect=C++11 --download-superlu_dist --download-mumps --download-hypre --download-metis --download-parmetis --download-scalapack --with-cc=mpiicc --with-cxx=mpiicpc --with-fc=mpiifort --with-debugging=0 COPTFLAGS='-ipo -03 -xHost' CXXOPTFLAGS='-ipo -03 -xHost' FOPTFLAGS='-ipo -03 -xHost' --with-blas-lapack-dir=$HOME/intel/mkl --with-mkl_pardiso-dir=$HOME/intel/mkl --with-mkl_cpardiso-dir=$HOME/intel/mkl
> The compiler that I m using comes with intel parallel studio 2019.
> As always every hints is hightly appreciated. Thank you very much!
> Edoardo Alinovi, Ph.D.
> DICCA, Scuola Politecnica,
> Universita' degli Studi di Genova,
> 1, via Montallegro,
> 16145 Genova, Italy
> Email: edoardo.alinovi at dicca.unige.it
> Tel: +39 010 353 2540
> <log.errors>
