[petsc-users] Error during install check - intel compiler
Edoardo alinovi
edoardo.alinovi at gmail.com
Mon Mar 11 16:13:46 CDT 2019
Dear all,
It's a while that I do not write here, hope you are doing all very well!
I am compiling petsc with intel, everything seems fine druing configuration
and make steps but when I perform the install check I get several errors
(attached the log file). Are they dangerous (they are not very
encouraging segmentation faults) ? What can I do to fix a bit the thing in
the case?
Configuration options are:
./configure PETSC_ARCH=arch-intel-opt --with-debugging=no
--with-cxx-dialect=C++11 --download-superlu_dist --download-mumps
--download-hypre --download-metis --download-parmetis --download-scalapack
--with-cc=mpiicc --with-cxx=mpiicpc --with-fc=mpiifort --with-debugging=0
COPTFLAGS='-ipo -03 -xHost' CXXOPTFLAGS='-ipo -03 -xHost' FOPTFLAGS='-ipo
-03 -xHost' --with-blas-lapack-dir=$HOME/intel/mkl
--with-mkl_pardiso-dir=$HOME/intel/mkl
--with-mkl_cpardiso-dir=$HOME/intel/mkl
The compiler that I m using comes with intel parallel studio 2019.
As always every hints is hightly appreciated. Thank you very much!
Edoardo Alinovi, Ph.D.
DICCA, Scuola Politecnica,
Universita' degli Studi di Genova,
1, via Montallegro,
16145 Genova, Italy
Email: edoardo.alinovi at dicca.unige.it
Tel: +39 010 353 2540
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190311/0c6ba3a9/attachment.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190311/0c6ba3a9/attachment.obj>
