[petsc-users] Conceptual question about DMDA
Smith, Barry F.
bsmith at mcs.anl.gov
Mon Mar 11 16:11:27 CDT 2019
Yuyun,
DMDA is an add-on on top of Vec/Mat (it doesn't replace anything in them)
DMDA manages the parallel layout of your structured grid across the processes so you don't have to manage that yourself. So, for structured grids using DMDA is actually easier than you having to manage partitioning the domain and setting up communication yourself. DMDA does it for you and choices partitions to minimize communications needed.
You should look at the examples in src/ksp/ksp/examples/tutorials for linear problems and src/snes/examples/tutorials/ for nonlinear problems that use DMDACreate to see what the code looks like. Pick an example that is like your problem and copy it as a starting point.
Barry
> On Mar 11, 2019, at 3:17 PM, Yuyun Yang via petsc-users <petsc-users at mcs.anl.gov> wrote:
> Hello team,
> May I know for what types of computations is DMDA better to use compared to regular Vec/Mat? It is more complicated in terms of usage, thus so far I’ve only used Vec/Mat. Would DMDA improve the performance of solving large linear systems (say for variable grid spacing as a result of coordinate transforms, with finite difference method)? What considerations should go into implementing it?
> Thank you very much!
> Yuyun
