[petsc-users] Imbalance in ParMETIS
Fri Jun 28 05:49:33 CDT 2019
On Fri, Jun 28, 2019 at 5:38 AM Eda Oktay via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Hello everyone,
> I am trying to change load balance in ParMETIS in order to give different
> number of elements to different processors. In the manual, it states that
> changing "ubvec" parameter should work. So, instead of 1.05, I gave 1.2,1.5
> and so on but load balance didn't change. I always get Max 5 Min 5 when I
> view load balance. The partitioning part of my code is:
ParMetis is always balancing. ubvec changes the balance between having even
partitions and a nice cut. If
you want unbalanced partitions, you have to change the vertex weights.
    Matt
>  ierr = MatConvert(A,MATMPIADJ,MAT_INITIAL_MATRIX,&AL);CHKERRQ(ierr);
>   ierr = MatPartitioningCreate(MPI_COMM_WORLD,&part);CHKERRQ(ierr);
>   ierr = MatPartitioningSetAdjacency(part,AL);CHKERRQ(ierr);
>   ierr = MatPartitioningSetFromOptions(part);CHKERRQ(ierr);
>   ierr = MatPartitioningApply(part,&partitioning);CHKERRQ(ierr);
>   MatPartitioningViewImbalance(part,partitioning);
> What should I do? Why changing ubvec didn't change anything, am I
> missing something?
> Thanks,
> Eda
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190628/3a9f6848/attachment.html>
