[petsc-users] PCFieldSplit additive and multiplicative operations
Justin Chang
jychang48 at gmail.com
Fri Jun 28 15:59:34 CDT 2019
Hi all,
Suppose I have a 2x2 block system of equations that I want to solve using
gmres + field split:
(A00 A01) (u0) = (b0)
(A10 A11) (u1) = (b1)
Based on what I understand from the PCApply_FieldSplit(pc,x,y) source code
<https://bitbucket.org/petsc/petsc/src/3b49ee3ec70d6dde98134df8f402aa75075296ac/src/ksp/pc/impls/fieldsplit/fieldsplit.c#lines-1194>,
the Block Jacobi (aka pc_fieldsplit_type additive) implementation performs
the following operations:
y0 = inv(A00)*x0
y1 = inv(A11)*x1
and for the Block Gauss Seidel (aka pc_fieldsplit_type multiplicative)
y0 = inv(A00)*x0
y1 = inv(A11)*(x1 - A10*y0)
But based on my understanding of the Jacobi
<https://en.wikipedia.org/wiki/Jacobi_method> and Gauss-Seidel
<https://en.wikipedia.org/wiki/Gauss–Seidel_method> methods, shouldn't the
above sets of operations be more like:
y0 = inv(A00)*(x0 - A01*y1_0)
y1 = inv(A11)*(x1 - A10*y0_0)
and
where y0_0 and y1_0 denote the initial/previous values of y0 and y1,
respectively? Or does it not matter as much because x0 and x1 don't exactly
correspond to u0 and u1, respectively, but instead correspond to either b -
A*u or A*vec_vv depending on the stage you're in inside the gmres solver?
Justin
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190628/ce195b84/attachment.html>
