[petsc-users] PETSC using 32-bit integers
Tue Jun 25 05:31:48 CDT 2019
For any performance question, we need to see the output of -log_view for
each case compared.
    Matt
On Tue, Jun 25, 2019 at 5:55 AM José Lorenzo via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> I have access to two PETSC installations: one using 64-bit integers and
> another one with 32-bit integers. For some reason, when I run the exactly
> same FORTRAN code (except for the size of integer type) using both
> installations, the 32-bit one exhibits much lower performance in terms of
> computation time. This is a problem because I need the 32-bit version in
> order to be able to use the LU factorization provided in MUMPS.
> I would appreciate any hint helping me understand why this may happen.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190625/6a226a2f/attachment.html>
