[petsc-users] MPI-FFTW example crashes
Sajid Ali
sajidsyed2021 at u.northwestern.edu
Sun Jun 2 23:52:15 CDT 2019
@Barry : Perahps config/BuildSystem/config/packages/fftw.py should use the
--host option when configure for PETSc is run with-batch=1.
If anyone here knows what --host must be set to for KNL, I'd appreciate it.
PS : I know that Intel-MKL-FFT provides FFTW api. If I'd want to try with
this, is there a way to tell PETSc to pick fftw functions from MKL ?
Thank You,
Sajid Ali
Applied Physics
Northwestern University
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190602/84538c96/attachment.html>
