[petsc-users] MPI-FFTW example crashes
Sajid Ali sajidsyed2021 at u.northwestern.edu
Sun Jun 2 23:46:09 CDT 2019
 Hi Barry,
fftw-configure fails on login node. I'm attaching the error message at the
bottom of this email. I tried request 1 hour of time on a compute node to
compile fftw on it but for some reason 1 hour is not enough to compile
fftw, hence I was forced to use cray-fftw-3.3.8.1 for which I had no
control over though the manpage gives a lower limit for compiler/MPT/craype
versions which I'm not violating.
sajid at thetalogin5:~/packages/petsc> python complex_int_64_fftw_debug.py
             Configuring PETSc to compile on your system
      It appears you do not have valgrind installed on your system.
      We HIGHLY recommend you install it from www.valgrind.org
      Or install valgrind-devel or equivalent using your package manager.
      Then rerun ./configure
      Trying to download http://www.fftw.org/fftw-3.3.8.tar.gz for FFTW
      Running configure on FFTW; this may take several minutes
         UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for
details):
Error running configure on FFTW: Could not execute "['./configure
--prefix=/gpfs/mira-home/sajid/packages/petsc/complex_int_64_fftw_debug
MAKE=/usr/bin/gmake --libdir=/gpfs/m
ira-home/sajid/packages/petsc/complex_int_64_fftw_debug/lib CC="cc"
CFLAGS="-fPIC -xMIC-AVX512 -O3"
AR="/opt/cray/pe/cce/8.7.6/binutils/x86_64/x86_64-pc-linux-gnu/bin/ar" ARF
LAGS="cr" LDFLAGS="-dynamic" CXX="CC" CXXFLAGS="-xMIC-AVX512 -O3 -fPIC"
F90="ftn" F90FLAGS="-fPIC -xMIC-AVX512 -O3" F77="ftn" FFLAGS="-fPIC
-xMIC-AVX512 -O3" FC="ftn" FCFLAGS
="-fPIC -xMIC-AVX512 -O3" --enable-shared MPICC="cc" --enable-mpi']":
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /usr/bin/mkdir -p
checking for gawk... gawk
checking whether /usr/bin/gmake sets $(MAKE)... yes
checking whether /usr/bin/gmake supports nested variables... yes
checking whether to enable maintainer-specific portions of Makefiles... no
checking build system type... x86_64-pc-linux-gnu
checking host system type... x86_64-pc-linux-gnu
checking for gcc... cc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling...configure: error: in
`/gpfs/mira-home/sajid/packages/petsc/complex_int_64_fftw_debug/externalpackages/fftw-3.3.8':
configure: error: cannot run C compiled programs.
If you meant to cross compile, use `--host'.
See `config.log' for more details
Thank You,
Sajid Ali
Applied Physics
Northwestern University
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190602/cc1688e0/attachment.html>
