[petsc-users] Question about correctly catching fp_trap
Thu Jan 3 18:48:14 CST 2019
On Thu, Jan 3, 2019 at 7:16 PM Sajid Ali via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Hi,
> I've compiled a program using petsc with debugging enabled.
> Confirmation of the same : https://pastebin.com/aa0XDheD (check if the
> loaded module is indeed petsc+debug, compile)
I do not see -g on your compile line. Do you?
    Matt
> When I run it in a debugger, I get the error as shown below:
> https://pastebin.com/GJtB2Ghz
> What am I missing?
> Thank You,
> Sajid Ali
> Applied Physics
> Northwestern University
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190103/86ce321e/attachment.html>
