[petsc-users] Question about correctly catching fp_trap
Smith, Barry F.
bsmith at mcs.anl.gov
Thu Jan 3 20:33:08 CST 2019
This appears to be more a spack question than a PETSc question. That make (that doesn't have the -g) is controlled by spack, not PETSc.
Barry
> On Jan 3, 2019, at 6:15 PM, Sajid Ali via petsc-users <petsc-users at mcs.anl.gov> wrote:
> Hi,
> I've compiled a program using petsc with debugging enabled.
> Confirmation of the same : https://pastebin.com/aa0XDheD (check if the loaded module is indeed petsc+debug, compile)
> When I run it in a debugger, I get the error as shown below: https://pastebin.com/GJtB2Ghz
> What am I missing?
> Thank You,
> Sajid Ali
> Applied Physics
> Northwestern University
